Water in taillight housing
  • 1 Post By Ray_Dockrey
Old 24 Aug 2013, 05:30 pm
Default Water in taillight housing
Daughter has a 2004 PT Limited. she get water in the driver side tail light assembly where it shorts out the bulb , she replaces bulb, lights work but a few weeks later its out again and there water in the assembly . any ideas where the water is getting in the assembly ? Ideas for a fix , other than a new assembly ?
Old 24 Aug 2013, 07:34 pm
randyincctx's Avatar
Lightbulb Re: Water in taillight housing
Does she use a coin-op car wash?.....And they do have a little rubber gasket around them;If it's worn,missing,or not seated correctly...It can get moisture inside.
Aka:~KILLER~
Old 24 Aug 2013, 07:40 pm
Default Re: Water in taillight housing
No car wash ... Are you talking about a rubber gasket around where the bulb twists in or where the whole assembly snaps into car body ?
Old 24 Aug 2013, 07:51 pm
There should be a rubber gasket/seal around the lens of the tail light assembly,and there should be rubber gasket/seal around the actual 'bulb holder/socket' also.....Check those out see if there there,and also see if they're torn/cracked,or have started to harden.(like an old rubberband gets,you know?)......The 'reverse/back-up' lights are very prone to moisture due to their location on the rear bumper,and location of the 'weep-holes'.
See these threads for more info:
water condensation in left tail light
Brake Light Condensation/Tail Light Replacement?
Aka:~KILLER~
Old 24 Aug 2013, 08:21 pm
Thanks ill check
Old 24 Aug 2013, 09:01 pm
Ray_Dockrey's Avatar
It's common. The 01-05's had issues and it didn't get any better for the 06-09's. My daughter's 06 is doing it and I noticed the other day my 09 is doing it. The seal between the lens and the back just breaks.
Old 24 Aug 2013, 09:05 pm
Wink Re: Water in taillight housing
I think the only change was a little 90 degree rubber tube/elbow,that's supposed to point down.....But,doesn't work much better than without it,and I've heard of people removing them with better results.
Aka:~KILLER~
Old 25 Aug 2013, 06:05 am
Actually there is more then just that. The way the sockets plug into the lights are different. So 01-05 won't work on 06 and up without some modifying.
randyincctx likes this.
Water in tail light housing? Ogrebro Tech & Performance Forum 4 12 May 2013 09:39 pm
3in1 Taillight? Jtwheels2007 Exterior Accessories Forum 1 15 Dec 2012 01:16 pm
taillight query keymon3891 General PT Cruiser Discussions 1 14 Feb 2009 10:15 pm
water neck for the water pump Boxerjl2 Classifieds: For Sale/Trade 3 31 Jan 2008 02:48 am
Yet another new PT taillight Stephen R. Exterior Accessories Forum 9 02 Apr 2004 06:45 pm
