easy question for y'all
  • 1 Post By Busted_PT
Old 25 Aug 2013, 12:25 pm
Default easy question for y'all
On pt cruisers, is the oil pressure light supposed to come on when the ignition is turned to the "on" position and then go off after the engine is started, like every other vehicle, I know the light is supposed to come on if there is a fault but mine never illuminates and I am throwing a code for it is this just some weird Chrysler thing that it doesn't come on?
Old 25 Aug 2013, 01:35 pm
Default Re: easy question for y'all
Mine is on anytime the key is in the run position and the engine is off
Old 25 Aug 2013, 02:00 pm
Replace the sensor. Then pull the speedo and fix the light that someone put out.
Old 25 Aug 2013, 02:55 pm
I've already had the cluster out because the two bulbs on the left side of the cluster were burnt out, after I replaced them the gauges lit up other than the speedo between 50-70mph area is still dark, the trunk light (which is right next to the oil light) illuminates, I didn't see a specific bulb for the oil light. There is a little silver round thing above right about where the oil light would be but I don't think it is removeable. I'm wondering if its just a bad spot in the cluster, since I'm throwing a code for an ops unit then the light should stay on.
Old 25 Aug 2013, 07:34 pm
randyincctx's Avatar
Post Re: easy question for y'all
I believe that is an LED soldered to the circuitboard,that probably would require taking the entire cluster apart,and possibly doing some surgical soldering to replace......Most of the factory LEDs in the cluster show a 10,000-15,000 hour life.
Aka:~KILLER~
Old 25 Aug 2013, 07:57 pm
Not if someone clipped it to put it out. Thinking it had no oil pressure. Rather than replacing the sensor first. Hard to sell one with oil light on.
randyincctx likes this.
Old 25 Aug 2013, 08:03 pm
Lightbulb Re: easy question for y'all
That does make alot of sense........Putting a piece of electrical tape (like I did for awhile with my O2 sensor on my old Toyota!lol) would just make someone say: "Why is there a piece of electrical tape on the gauge cluster???"
Aka:~KILLER~
Easy fit HID headlights in UK Jassy Europe PT Forum 0 08 Apr 2013 04:08 pm
Can it be that easy? Excoastie General PT Cruiser Discussions 10 22 Feb 2012 07:36 am
oil change easy? demon666 Tech & Performance Forum 7 15 Jul 2009 08:04 pm
Cool is not as easy as it seems skylight PT Cruiser News and Rumors 5 08 Feb 2008 09:07 pm
