Mystery bolt on 2003 Manual Trans
Old 25 Aug 2013, 04:41 pm
Question Mystery bolt on 2003 Manual Trans
I removed the bolt in the picture below thinking it was the 5spd trans drain plug.
I quickly reinserted it. Have I done any damage?
What is this bolt?
This is taken from the front right side of the car looking up at the trans.
Old 25 Aug 2013, 06:06 pm
Default Re: Mystery bolt on 2003 Manual Trans
That bolt is for the reverse idler shaft. Since you just took it out and put it back you should be fine. Row the shifter, do the gears all feel ok?
Here's the trans manual if you need any more info about it. http://oskin.ru/pub/chrysler-dodge/m...3;_NV_T350.pdf
The drain plug is right below the rubber fill plug IIRC
Old 25 Aug 2013, 06:32 pm
UptownSport's Avatar
^^^ Yep! Exactly!
If you were able to get it to tighten, you're OK.
Forget about it (not to the extent you do it again ) and keep on cruisin'!
2005 Manual Trans Not Shifting... Micki General PT Cruiser Discussions 3 14 Feb 2015 03:46 pm
Manual trans Cruser need help!! jrod1295 Tech & Performance Forum 1 18 May 2012 11:48 pm
manual trans noise wyok General PT Cruiser Discussions 2 12 Oct 2010 05:28 pm
FS-stage 1 for 03 manual trans nuptgt4me Classifieds: For Sale/Trade 5 22 Apr 2010 11:10 pm
New 08 manual trans question... pigmywolf Tech & Performance Forum 5 21 Sep 2009 08:10 pm
