Engine error / need help ASAP
Old 25 Aug 2013, 09:29 pm
Default Engine error / need help ASAP
I have a 2003 pt cruiser gt ,, check engine light has came on and have lost power ( acceleration , it's bogging down , shaking ) , engine codes p0351 , and most recently p0300 ,, have changed the coil , spark plugs , wires , and crankshaft positioning sensor ,,, and the problem is still happening ,,, been to a mechanic multiple times ,, this is a continued stress and I need help ASAP ,,, ANYBODY PLEASE !!
Old 26 Aug 2013, 08:52 am
Default Re: Engine error / need help ASAP
Tery the cam sensor. Bur first check the wiring to both crank and cam sensors for any sign of damage. The 300 may be a symptom of the other code.
Old 26 Aug 2013, 04:35 pm
Thanks I actually started having the problem again while headed to the local parts store to purchase the cam sensor and I got under the good wiggled the wire around leading to the can sensor and the car ran great , the most quietest it has been ,,, I'm keeping fingers crossed this is the problem ,,, won't know for sure until myself or the mechanic have put it in ,,, but I want to say thank you for the advice ,, sincerely
Old 26 Aug 2013, 04:40 pm
Sounds like the plug and or wiring may be your problem sense the wiggling made a difference. I would look at that more. Moving the wire should not have made a difference other wise. Your welcome as always.
Old 27 Aug 2013, 02:56 am
Busted; That's good advice.
Old 28 Aug 2013, 12:15 pm
Smile Re: Engine error / need help ASAP
Well just have to wait to have someone help me in putting in the sensor and checking the wiring , etc , sooo now it's just a waiting game but I did buy the new CAM sensor and am also going to by the Connecter as well and when I an get my mechanic to work on it ill know if it's the problem or not ,,, I was thinking of doing it myself ,, just haven't ever really worked on things other than minor things ,,, wondering if it's something I can do myself possibly ??
Old 28 Aug 2013, 12:40 pm
An 8mm wrench or socket and the plug in. That's about all there is to it.
Old 29 Aug 2013, 09:57 am
Hope you bought a Mopar cam sensor - mystery brands often don't work or only work for a short time.
'02 Engine rattle, error codes, runs rough 76911S Tech & Performance Forum 5 19 Sep 2012 12:48 pm
engine trouble, no error code apsenniel Tech & Performance Forum 10 05 Aug 2012 08:08 pm
Error Code P0303/Check Engine Light ohiomas Tech & Performance Forum 1 10 Apr 2011 02:47 pm
Engine Light ON - no error code PeeTeeCruizer Tech & Performance Forum 2 23 Oct 2010 02:32 pm
Engine light P2097 error code help jbh1860 Tech & Performance Forum 2 20 May 2009 12:30 pm
