Radiator Fan Replaced - still have issues!
Old 27 Aug 2013, 08:39 am
Default Radiator Fan Replaced - still have issues!
Replaced it myself at 133,000 miles - 2001 PT Cruiser. Firestone wanted $480 to do it. I got a replacement from Advance Auto (matched price from RockAuto) for about $90, and installed it myself.
Firestone had said the old one was burnt out and was causing various problems.
After installing -
the fan still does not run
the car won't go above 35-40mph or 3,000 RPM with extreme bucking!
transmission does not shift to 2nd gear or more
odometer now does not work
I did the cause code lookup described herein and got these codes:
P 1684 - Driver 5 Line 4 -
P 0645 -
P 1489 -
P 1490 -
P 1495 -
What to do now? Appreciate any suggestions!
Old 27 Aug 2013, 09:02 am
Default Re: Radiator Fan Replaced - still have issues!
Have the codes cleared. This help another member with a similar issues.
Old 27 Aug 2013, 09:06 am
Can I do this just by disconnecting the Negative battery connection for a couple minutes? or does it need to be someone with a Code device?
Old 27 Aug 2013, 09:35 am
Ray_Dockrey's Avatar
Disconnecting it will work just fine.
Old 27 Aug 2013, 09:36 am
Also make sure that everything is connected and all vacuum hoses are connected.
Old 27 Aug 2013, 12:23 pm
OK
Just went home and pulled negative from battery for 15 min, then reconnected it. I double-checked all connections.
I then started it and immediately took it for a short drive and got the same symptoms - car bucking severely at roughly 3,000 RPM and not letting me go any faster! The A/C still doesn't work and now the odometer is not reading!
I drove back to the driveway and did the cause code lookup described herein and got the same codes again:
P 0645 -
P 1489 -
P 1490 -
P 1495 -
What did I do wrong? Should I have let car idle for a while?
Old 27 Aug 2013, 06:53 pm
any other ideas? can use the help!!
Old 28 Aug 2013, 01:24 am
The 3000 rpm thing could be a bad cam sensor. Recheck the wiring/connectors. Strange this all happened at once.
Old 28 Aug 2013, 07:25 am
Thanks, will try that next I guess, though the code for that hasn't come up. All the codes seem to be related to fan or A/C relays.
Yes - it is very bizarre that all would happen at once.
Reading a couple other articles about being RPM limited - could the "limp in" mode be on in this car, and if so - how do I get it out of that?
Old 28 Aug 2013, 10:34 am
Should I try replacing all the relays? I can't tell if they are working or not - or is there a way to tell?
Replaced Radiator Fan Assembly - Still no fan movement sputnik Tech & Performance Forum 11 17 Apr 2015 07:43 am
MFS Replaced. Right fog light issues PTVibe General PT Cruiser Discussions 0 21 Feb 2013 03:27 pm
Radiator Issues Bretalexa Tech & Performance Forum 7 24 Apr 2012 03:04 pm
Radiator replaced, now leaking power steering fluid JamesPisanich General PT Cruiser Discussions 3 30 Sep 2011 10:23 am
