04 Cruiser just idles?
Old 27 Aug 2013, 12:31 pm
Default 04 Cruiser just idles?
My daughter has a 04 Cruiser that we've had trouble with in the past. I've replaced the fuel pump, cam & crank sensor, plugs and wires, replace timing belt and tensioner and lastly the computer. Its ran flawlessly for the last three months. She called this morning and said it quit on the way home from work. She said it dropped to an idle and stay there even when she was stepping on the gas. Could this be the TPS or IAC? I haven't been home to check it yet.
Bob
Old 27 Aug 2013, 07:16 pm
Default Re: 04 Cruiser just idles?
Bob
Could be in limp mode or from this description, something with the throttle cable?
Old 27 Aug 2013, 09:56 pm
No, not limp mode. Crank sensor was out again. I replaced it 15 months ago. Running good again, it's just for how long.
Bob
Old 27 Aug 2013, 10:03 pm
Bob
Some think the aftermarkets are problematic. Inspect the wiring for damage if you have more issues.
05 PT Cruiser Error Codes & Idles high GA81PEACH19 Tech & Performance Forum 5 06 May 2013 10:41 pm
PT Cruiser starts, idles for 2 min, stalls, then will not start enviroPT Tech & Performance Forum 7 14 Jan 2013 12:17 pm
2007 pt cruiser high idles tonybouc Tech & Performance Forum 10 04 Jan 2012 10:13 pm
05 pt cruiser idles rough and stalls at idle wncengine Tech & Performance Forum 0 08 May 2009 10:31 am
PT idles low and seems like it's going to die with AC on churdiales Tech & Performance Forum 6 30 Aug 2007 09:01 pm
