02 Crusier Misfiring Problem
Old 27 Aug 2013, 05:25 pm
Unhappy 02 Crusier Misfiring Problem
This all started with the engine running a little choppy and I noticed that spark plug wires 1 and 4 weren't sparking at all at the tips when touched to metal. I could turn off the car, and turn it back on and every so often they would start firing again but usually not.
Found oil on all 4 spark plugs. Put in new plugs and hooked everything up and it was running fine... for 1 day.
Next day same problem, oil on the new plugs again and misfiring. I replaced the valve cover gasket to hopefully solve the oil on the plugs problem.
Had the coil pack tested at Autozone, they said it was good. I know the previous owners had replaced the coil pack twice in the last year, so I'm confident that the one we have is good.
Where do I go from here? New set of clean plugs are on order, any advice to fix the misfire?
Old 27 Aug 2013, 05:53 pm
randyincctx's Avatar
Post Re: 02 Crusier Misfiring Problem
Take a little time and check the wiring for the CPS & CKS end-to-end,including the connectors....Look for cracks,wear,or even bare wire(s) especially around the transaxle.....Also,have you checked for any error codes?
Aka:~KILLER~
Old 27 Aug 2013, 06:41 pm
Default Re: 02 Crusier Misfiring Problem
Some links to read...
Oil on my sparkplugs?
Oil in my #1 Cylinder
What does it mean when your car spark plugs are covered in oil? - Yahoo! Answers
What does it mean when my spark plugs are covered in oil when i get it out of the engine. 2000 honda civic si? - Yahoo! Answers
Old 29 Aug 2013, 03:55 pm
like I said I replaced the valve cover gasket and hopefully that will fix the oil problem.
But where do I go from there? And where can I find the CPS / CKS on the car?
Old 29 Aug 2013, 04:55 pm
CPS / CMP
CKS / CKP is right above the oil filter on the 2002 PT.
Old 30 Aug 2013, 08:46 am
You say you replaced the valve cover gasket - did you replace the 4 gaskets - 1 for each spark plug well? THat would be where the oil gets in to the plugs.
Did you clean up the spark plug wells of oil after you replaced the valve cover gaskets?
Old 07 Sep 2013, 09:42 am
Yup shined everything up and replaced all the gaskets. Took a lot of time getting it all clean
Old 15 Sep 2013, 09:57 pm
Put new spark plug wires on and new plugs - nothing. New coil pack sound like sure thing?
Tags
2002, coil pack, misfire, oil on plugs, pt crusier
a/c problem o4 pt crusier 2.4 non turbo victor Welcome New PT Cruiser Members 1 20 Sep 2012 11:28 am
04 PT Starting Problem including misfiring mt04pt General PT Cruiser Discussions 9 26 Aug 2012 12:10 pm
Manifold pressure sensor problem and misfiring Binny Tech & Performance Forum 1 08 Feb 2012 02:41 pm
help having problems car misfiring bigjimmiefl Tech & Performance Forum 8 04 Apr 2011 06:26 pm
code for misfiring cylinder bbromero Tech & Performance Forum 6 08 Jun 2010 01:50 pm
