quick torque spec question
Old 28 Aug 2013, 04:10 pm
Peeeteee's Avatar
Default quick torque spec question
Hey everyone:
I'm in the process of (re)doing my timing belt (belt is off a tooth), and I wanted to know if anyone knows the correct torque spec for the two 15mm bolts that connect the upper torque strut to the bracket on the engine?
The listed spec is 87 lb-ft, which seems correct for the 19mm bolt, but too high for the 15mm bolts. When I did the job the first time, I actually snapped one of the bolts, and only by the grace of God it stayed in one piece and came out.
Pic:
Thanks everyone.
Patrick
Old 28 Aug 2013, 06:47 pm
UptownSport's Avatar
Default Re: quick torque spec question
That's too high. I'd do it by feel, never torque on those
Old 28 Aug 2013, 07:15 pm
Originally Posted by Peeeteee View Post
Hey everyone:
Pic:
Thanks everyone.
Patrick
Most things are inch pounds not foot pounds on these.
Old 28 Aug 2013, 10:56 pm
Peeeteee's Avatar
Maybe so there's no miscommunication, here're the bolts I'm talking about.
Two 15mm and one 18mm (the 19mm above is a mistake)
The Chilton Manual seems pretty clear that the spec is 87 POUND feet. Pic:
So I'm wondering if my manual is wrong or if my torque wrench is broken. Maybe just use "German torque" (good and tight)?
Thanks again everyone.
Patrick
Old 29 Aug 2013, 01:40 am
Peeee; for a 2006 the torques are 85 or 45 foot lbs. There are torque charts for different bolt sizes and grades all over the net. The torques given are based on the diameter of the bolt, NOT on the size of the hex [or socket].
Double check my numbers, as the pictures were a little confusing.
Old 29 Aug 2013, 11:00 am
Peeeteee's Avatar
I tried to post a reply last night, so hopefully it goes through this time.
Just so there is no miscommunication, here are the bolts I'm talking about (actually, the holes where the bolts go.) There are two 15mm bolts and one 18mm bolt. (the 19mm above was a mistake). These bolts hold on the upper torque strut.
The Chilton manual seems very clear that the spec for these bolts is 87 POUND feet:
So, it seems that either my manual is wrong, my torque wrench is smurfed up, or there's some other problem. One other thing I think is a little weird is that these bolts seem to be aluminum or something similar, and I wonder if that makes a difference. Still the spec is supposed to be 87 lb-ft, which is high, but these are also large bolts.
Maybe just German torque? (good-and-tight)?
pt06- thanks. I know that the bolts are not the size of the socket - i.e., I realize that the bolt shank is not 18mm thick. However, bolts are normally referred to by the size of the wrench used on them, not the diameter of the bolt. i.e. a 9/16" bolt is 3/8" thick. When one refers to the bolt itself, one would say M10, M12, etc.
torque spec for intake manifold oldfatman Tech & Performance Forum 12 26 Jun 2014 11:51 pm
torque spec: upper transaxle mount to bracket bolts fatbastardracing Tech & Performance Forum 2 01 Dec 2012 07:49 pm
Torque spec astro9205 Tech & Performance Forum 1 15 Sep 2012 10:53 pm
Bolt torque spec for when replacing timing belt? unioncreek Tech & Performance Forum 4 20 Jul 2012 04:31 pm
Strut bolts torque spec's? silky Wheels, Tires, Suspension 4 21 Jan 2004 11:17 pm
