Battery Light Trouble
Old 29 Aug 2013, 08:46 am
Default Battery Light Trouble
Hi all, new poster here, I have a 2001 PT Cruiser that is just driving me crazy! The battery light started turning on a few months ago and I had to ignore it because I was way too broke to do much about it. About three weeks ago I ended up having a problem with my rear door sensor that made the lights and alarm turn on all the time at random-- that got fixed.
But three days later the car flat-out would not turn on. Got it jumped but the power wouldn't stay and it shut down. Had to get it expensively towed.
The shop I usually go to found that the battery was entirely dead-- they thought there might be something wrong with the alternator. They replaced the battery and, lo and behold, the alternator still seems fine. They figured the rear door sensor problems just drained it.
Two weeks later my battery light is coming on. What the crazy could be going on here?
Old 29 Aug 2013, 09:12 am
Default Re: Battery Light Trouble
Do you have fog lights?
The multi-function switch dies and turns the fog lights on without the key and the only way to fix it is remove the fuse or put in a new switch (be sure to get one with fog lights and be sure to move the flasher module from old to new switch.
Old 29 Aug 2013, 09:24 am
Sorry, a bit unsure, but I feel I might notice if I came back to my car and the fog lights were on... yes? I mean, I don't know too much so I could just be crazy.
Old 29 Aug 2013, 09:48 am
Don (Quisksilver) was trying to say that the most problems we see on this forum from a dead battery is that the multi-function switch which controls the headlights and fog lights and turn signals burns out and when it does, most of the time the fog lights stay on, which in turn run down the battery.
So, easy enough, try your fog lights. Turn them on and off. The green light on the dash should light up if they are on and go off when you turn the fogs off. If all that works, something else is draining your battery and a system check for a drain has to be done....a long and drawn out procedure.
Old 29 Aug 2013, 10:04 am
Just checked that and the green light you described isn't coming on. So I guess it's the fuse. Any idea how much this might cost?
Old 29 Aug 2013, 10:11 am
The question is, are the fogs on ALL the time, or just not coming on when you try the switch? Were they working before this time, have you used them before?
Check to see if fuse #8 in the interior fuse box is good. That supplies voltage to the fogs.
Tags
2001 cruiser, alternator, battery, wiring
Fog Light Trouble BigT General PT Cruiser Discussions 3 15 Jul 2013 09:05 pm
Trouble light code rainier42 Tech & Performance Forum 2 22 Feb 2010 04:48 pm
trouble with fog light switch? twins4me General PT Cruiser Discussions 18 22 Nov 2009 04:44 pm
light trouble bobs turbo pt General PT Cruiser Discussions 3 29 Jun 2009 10:46 am
