Raising the front end
Old 29 Aug 2013, 10:26 am
Default Raising the front end
I am looking for an easy (if possible) way to raise the front end about 3 to 4 inches. I am not a big fan of the factory "California Rake" look, but the main reason is speed bumps. If you have ever driven in Mexico, you know what I mean.. I checked the internet, and most applications are for lowering.
So, any suggestions would be appreciated/
Old 29 Aug 2013, 11:01 am
Default Re: Raising the front end
Here is the best way to go over those nasty speed bumps
Or this
Old 29 Aug 2013, 11:06 am
adjustable coil overs?
Old 29 Aug 2013, 12:46 pm
This is not a sound way to raise a vehicle as per the OP 3-4 inches.
Moving on... 3 inches is a lot to raise or lower any vehicle form stock specification and 4 inches raised on a car inches is high level moding consideration.
The easiest way to get a safe and affordable 2 inches raised on the front is to have a strut tower spacer fabricate much the same way a wheel spacer is made.
You might reconsider and try 1-2 inches first?
Old 29 Aug 2013, 01:58 pm
I like my answer better
Old 29 Aug 2013, 04:11 pm
cruserdad1976's Avatar
I agree to rais a car 4 inches is a PAIN a turn is not all that easy but a frount wheel drive car to do it right will get expensive id do as Nitro says and try 2 inches and see i live out inn the country so i have gravel roads with big rocks but mine usally clears them
Old 29 Aug 2013, 04:16 pm
I like the strut tower spacer idea. I will check it out this weekend.
I would be a bit concerned if it would stretch out the shock hydraulic post too much doing that????
Old 29 Aug 2013, 05:06 pm
With that spacer Nitro talked about the entire shock is spaced down. No change as far as the shock is concerned. But will give a steeper angle on the axle, as all lifting Technics will.
Old 30 Aug 2013, 08:42 am
3-4 inches is a LOT.
You can get a modest rise by lowering the rear, and lowering the rear is certainly easy to do with lowering springs - I lowered the rear of mine and the front went up a little, and got rid of much of the "Butt in the air" look, which, to me, is stupid on a FWD car.
After I lowered the rear, clearing the dip at the end of my driveway without scraping became much easier.
Old 30 Aug 2013, 01:33 pm
Teska's Avatar
Raise the front end ?
Sorry, but a stock PT is at Jeep height. If that's not enough for you I've got two questions:
1. How fast do you go over speedbumps ?
2. How high are speedbumps where you live ?
PT Cruiser 05 base 1,6 liter Electric blue.
Natural gas system build in.
Lowered with FK coilovers.
Installed Mopar sub !
WTB: 01-05 passenger front fender & front bumper cover g60racer Classifieds: Want To Buy 2 16 May 2013 04:39 pm
Moog bushings and raising the PT Dace Wheels, Tires, Suspension 3 03 Mar 2013 05:56 am
Raising Front of Vehicle SILVERONE Turbo Wheels/Suspension/Handling 4 08 Jul 2008 07:24 am
Raising PT Cruiser??? KevinM Turbo Wheels/Suspension/Handling 7 25 Jul 2003 04:10 pm
Raising the hood. Dennis General PT Cruiser Discussions 3 08 Jan 2003 05:31 pm
