recovery tank question
Old 29 Aug 2013, 07:31 pm
Default recovery tank question
this is my first car, with coolant recovery tank close to dash . I hear the coolant flush in and out of the tank ,once in awhile does not overheat, stays on full mark, a/c ice cold, on a 100 degree day. my question is this normal to hear the coolant working.
Old 30 Aug 2013, 08:53 am
Default Re: recovery tank question
Just keep an eye on the coolant level. As long as it's over the low mark, you're okay.
You can use Zerex G05 antifreeze.
Old 07 Sep 2013, 01:01 pm
thanks, is the zerex G05 that important ? I had new water pump and timing belt installed and green prestone was put back in. the man said as long as its flushed and all one kind its ok. I dont want to mess care up .
Old 07 Sep 2013, 01:11 pm
randyincctx's Avatar
Post Re: recovery tank question
It should be OK,even though MFG recommends HOAT.....I have read several threads where members have switched to Ethyl Glycol,instead of HOAT,and apparently had no problems afterwards....But,only after a thorough flushing;The problems arise from mixing the two coolants together,they tend to 'Gel' when mixed,thus creating clogs throughout the cooling system.
Aka:~KILLER~
Old 08 Sep 2013, 05:04 am
From what I've read, regular antifreeze should be changed every 2 years. Chrysler says HOAT should last 5 years. It's a corrosion thing.
There's a great article on this site about it.
broken coolant recovery tank 4SPEED General Turbo Discussions 5 29 Aug 2012 06:31 pm
Cleaning the Coolant Recovery Tank Badglas General PT Cruiser Discussions 6 29 Aug 2012 04:47 pm
Catch tank question Arthur General Turbo Discussions 8 29 Oct 2011 11:24 am
broken yellow recovery tank cap fix 4SPEED General PT Cruiser Discussions 0 14 Mar 2011 01:37 pm
Overflow tank question sirhubbs Tech & Performance Forum 3 15 Dec 2010 06:14 am
