I think I'm limp?
Old 03 Sep 2013, 07:56 am
Default I think I'm limp?
New to the scene here (already did the intro post ) I have been doing several searches on a collection of issues (or at least what I would call issues) with the PT Crusier I bought for my daughter. One big one... After we bought it where it would simply loose all power and just shut down. We took it to a few different spots even the local dealer and got mixed answers.
After getting the run around, I finally found someone who suggested the issues were related to the ECU going bad. We ended up replacing the ECU with a used one. It was re-programmed and the stalling has stopped and overall seems to be responding ok
However, now among the shop saying new motor mounts, and lower control arm the car seems to show symptoms of this "limp" mode I am reading about. I am new to American cars but I have never heard of this. But the symptom is this, when in park, I rev the engine and around 3000 rpm, it begins to drop then go back up. Not that I am trying to blow the engine but in all cars I have had, you rev the engine, it goes until you take your foot off or you blow the engine.
I get a similar feel when I take the car above the 70 mile an hour point. It gives a hesitation which almost feel like it will stall but then when you get the rpms down or it shifts gears it runs normal again. I did the code check and its throwing no codes. Someone also suggested it could be a PCV valve issue or hose.
Is this normal? What items should I be looking at first?
The issue is pretty inconsistent. I am getting the oil changed today along with transmission flush just because I am not sure of when the last ones were done but I am worried that I may be looking at several more trips or late nights in the garage fixing this thing.
I am also not sure of well this was taken care of based on what I see in the CarFax. Outside of a few small trips for what are probably oil changes, I see no regularly scheduled maintenance records. So either the prevous owner did there own, I need to know play some catch up on a few items.
My daugter is about 3 hours away at school so I need to know this car is solid before I let her take it down there. The car itself isn't in bad shape overall. The engine bay is pretty clean, some rust spots on the wheel wells but overall good looking ride. Interior is clean for an older car but I have to know it wont break on the side of the road.
Old 03 Sep 2013, 08:18 am
Default Re: I think I'm limp?
The engine computer prevents revving while in neutral.
On the road the hesitation may be caused by spark plugs/wires.
Plugs - the stock Champions are okay - gap at 0.040 - and replace the wires at the same time - the stock wires do not last - the best I've found are Crane firewires.
Even if the plugs/wires don't cure your hesitation, it can't hurt - look in the tech forum, there's a how-to on changing the plugs.
Old 03 Sep 2013, 11:34 am
randyincctx's Avatar
Wink Re: I think I'm limp?
In my own personal opinion,PT Cruisers aren't technically an 'American Car'.....Because they are built in Tolouca,Mexico by citizens of Mexico....And Chrysler is a consolidated subsidiary of Italian multinational automaker Fiat,at the time PT Cruisers were being made,Chrysler was owned by German automaker Daimler-Benz....Which they made vehicles under the corporate name 'DaimlerChrysler'.........With that info in mind;What do you think?LOL
Aka:~KILLER~
Old 03 Sep 2013, 11:48 am
Most cars have rev limiter to prevent that reving till it blows. The hesitation, I would check the above suggested maintenance and see what you have.
Old 03 Sep 2013, 01:20 pm
nice, but still doesnt count.
The plugs and wires were already replaced a few months back but I suppose I could take a quick look at that. I did not do these myself so I am not sure of the type.
Old 04 Sep 2013, 03:46 am
What year PT? How many miles?
btw...you are not in "limp mode"...(vehicle remains in second gear only).
Old 04 Sep 2013, 07:02 am
Exclamation Re: I think I'm limp?
Having a daughter in college and having
A car Not being able to go above 70 mph.
Most parents would be quite pleased to be in your shoes!
Old 07 Sep 2013, 07:18 am
2004 with 130k..if it were just that it wouldn't over 70 then your right I'm probably ok with that. Just afraid it will simply die out. Have replaced wires and plugs so hopefully this will solve it for now. Next up is motor mounts which from the posts I have found looks easy enough. After that I think she needs to get this car out f my driveway before I do more things to it
Limp Mode? Bentron General PT Cruiser Discussions 23 21 Jun 2016 10:54 am
stuck in limp mode galahad General PT Cruiser Discussions 3 13 Feb 2013 07:44 am
Air bag deployment and limp mode Hvymtl Tech & Performance Forum 1 25 Aug 2011 03:36 pm
help..limp mode ivynthemnts758 Tech & Performance Forum 2 09 Sep 2010 08:44 am
01 cruiser in limp mode mui5m General PT Cruiser Discussions 1 04 Dec 2009 02:19 pm
