overheating after 150 miles!
Old 03 Sep 2013, 09:48 am
Default overheating after 150 miles!
I have a 2008 pt cruiser(not a turbo). I runs hot after driving about 150miles!. I had to turn heat on to help it cool down some. Once it runs hot it pushes all the fluid out of the system via the overflow spout. I have took it to 3 different shops who have pressure tested it, flush the radiator a total of 4 times, change the thermostat twice. all of this was in the last week. another problem is I have only had the car a week! it has about 58000 miles on it. what could be causing the slow overheating? like I said it overheats, then pushes fluid out of the overflow making you low on fluid, so you wait until cool, then added fluid again. any suggestions
Old 03 Sep 2013, 10:54 am
Default Re: overheating after 150 miles!
Does the radiator fan come on??? It should come on whenever the A/C is on, so open hood, start car, turn on A/C, and listen for engine fan.
Old 03 Sep 2013, 11:18 am
randyincctx's Avatar
Post Re: overheating after 150 miles!
One of the most common things that will make a PT Cruiser overheat is air in the cooling system;It must be properly bled,to remove all air from it......And after losing coolant,there will obviously be air in the system.....For more info see: Bleeding air from cooling system
Aka:~KILLER~
Old 03 Sep 2013, 11:53 am
cruserdad1976's Avatar
so are the 150 miles city or highway??
Im thinking fan but surely some one would ahve checked that before 4 flushes
air in the system is a possablity but again after 4 flushes it should be bleed
you say they did a pressure test so that rules out head gasket
right now id say fan unless the 1250 miles are highway them im not sure
HOW MANY MILES ON YOUR PT???? mjb457 General PT Cruiser Discussions 1228 20 Nov 2019 11:56 pm
171,000 MILES jimeb General PT Cruiser Discussions 14 10 Feb 2013 04:15 pm
05 with 140 miles mlaw48 PT Cruiser Convertible Forum 0 26 Feb 2006 11:16 am
who has the most miles on their PT VellianPT General PT Cruiser Discussions 34 01 Jan 2005 10:30 pm
2,289 miles later... beebs General PT Cruiser Discussions 1 15 Jun 2003 09:31 pm
