OK. so I just did my first oil change on the PT. I put 4 qts in and started engine, had a check engine light at startup. Added the last quart just to be sure I didn't over fill. Still have the engine light. Do you have to do a battery disconnect eveytime you change oil to clear this light? Or will it clear itself?
Thanks |
Was it on or off before you put the oil in?
Kingkole02 Just Cruisin, 03 N/A auto. TE Steel Blue w/ pearl coat & chrome package. Too many extras to list, see pics |
Blade,
No, the "check engine" light shouldn't come on everytime you change oil, unless the code is telling you that your low on oil. YES, you have to disconnect the one side of the battery to reset the light, preferably the negative side.
KingKole, no check engine light before oil change.It probably did show low oil pressure as I was one quart low and it takes a few seconds to pump up pressure after a oil change, strange though you guys are not getting the light after a change.
03 Electric Blue Touring PT |
Blade,
My dealer does my changes, that something I won't mess with. Im not good with personal oil changes myself, yet.
Have you checked for oil stains on the ground where you park it of anything like that. I noticed this in my oil Nissan, the oil crank seal went bad. Sometimes you can loose oil if the filter isn't set 100% right.
KingKole...yeah, no leaks, I've been doing 90% of my own mechanic work for 35 years now, even did part time work in a local shop for a while, but this computer stuff is getting to me.[
]I'me pretty sure it was a low oil pressure warning, but you would think they would have a few second delay for oil changes. I pulled neg battery cable and all is fine now.
Glad you figured it out Blade.I've changed oil in
my Cruiser ,never had that problem.
04 cool vanila Limited Turbo ![]() Wife has a 03 limited (Steel Blue) |
| "Check Engine" idiot light on AGAIN | tezz | General Turbo Discussions | 15 | 23 Jul 2010 06:09 am |
| Check Engine Light | jmack | General PT Cruiser Discussions | 10 | 25 Jul 2009 11:16 am |
| Check Engine Light | CHROMEDCRUISER | General PT Cruiser Discussions | 11 | 16 Jul 2008 11:46 pm |
| Faulty Check engine light? | Mel K | General Turbo Discussions | 5 | 23 Mar 2007 10:06 am |
| Check engine oil light question | AaronR | General PT Cruiser Discussions | 5 | 28 Aug 2004 03:18 am |
