rough idle
Old 08 Sep 2013, 07:21 pm
Default rough idle
Hello all you PT enthusiasts!
First time texter so be nice.
My daughter has a base 2006 PT Cruiser, it has a very distinct engine shake to it. I replaced the upper left and lower left engine mounts and that really helped but it still shakes. I went to the auto parts store and they suggested that I remove and inspect/clean the AIC valve. I did this and found it to be clean and operating as it should. now, the interesting part, I disconeted the Proportional Purge hose next to the AIC valve and the engine idled rock solid. I reconnected the hose and it started shaking again.
My question is, where does that hose go to and what is it connected to? Is there a filter that may be clogged?
I tried to blow into the hose and could not so it is either clogged or goes to a valve or something that is activated via vacuum.
Please let me know what additional information yo folks may need and I will provide as this problem is driving me crazy.
Thanks!
Mike
Rough Idle-Replacing the IAC Idle Air Controller engineerrock Tech & Performance Forum 9 07 Jun 2014 07:24 pm
'07 PT - Rough Idle, rough acceleration, and shuts off if it idles for too long La_Bruja Tech & Performance Forum 3 09 Aug 2013 07:50 am
Rough Idle 32seventeen Tech & Performance Forum 4 15 Jan 2013 10:10 am
Rough Idle Shrub723 General PT Cruiser Discussions 5 01 Feb 2012 06:55 pm
Rough Idle, Rough @60, check engine light NEW Dystroy Tech & Performance Forum 8 12 Jan 2009 09:07 pm
