Tightening Alternator Belt
Old 27 Sep 2013, 07:11 am
falconut's Avatar
Default Tightening Alternator Belt
Replaced both my Alternator and Drive belts last weekend. Afterwards, when the car is cold, when I am driving and stop at a light, I can hear a quick belt squeal. It goes away right away, just seams to be when I first come to a stop.
When I installed the belts I tightened the alternator belt so that I could turn the belt 90 degrees. I tried to check this morning from the top when I got to work and it might be a little more. Is it typical for them to loosen a little just after installing?
I had searched online and found a video where this guy said that if you can flip the belt 90 degrees it's correct. Maybe this is incorrect? How do others measure tightness for the Alternator belt? I don't have the money for the fancy tool they reference in the books. I'm going to tighten a little this weekend, just wanted to know if there's a better way.
Old 27 Sep 2013, 07:24 am
Default Re: Tightening Alternator Belt
That isn't necessarily the correct way. A shorter belt would be looser than a longer one, with that method. Probably one more round on the belt will be good. a new belt stretches a little after you run it. I like to tighten to the point that it stops squeaking . Over tightening will shorten the life of the bearings.
Old 27 Sep 2013, 08:04 am
falconut's Avatar
Not sure how the length of the belt would determine the tightness with my method. Maybe I didn't explain it good enough. I tighten the belt, regardless of size, until I can only flip the belt sideways about 90 degrees (from flat to straight up). If you understand me.
I didn't hear it making any squeaking when I did it. It started a few days later, so I guess it stretched. Just curious if there's a a special method people use for tightening it.
Old 27 Sep 2013, 09:14 am
i do what you did, then i had to tighten it a little more a few days later.
Old 27 Sep 2013, 11:59 am
falconut's Avatar
Sounds like I'm on the right track then. Just wish it wasn't such as pain to get to these bolts.
Old 27 Sep 2013, 03:22 pm
A shorter belt will feel stiffer between pulleys. A long span between pulleys would require s lot more tightening to get it that stiff. And would be more pressure on the bearings that it would be turning. Test the longer belt for the AC and power steering. Non adjustable. You can flip it way past 90 and it's self adjusted.
Old 27 Sep 2013, 04:54 pm
falconut's Avatar
Now I get what you're saying about the length.
Alternator belt help! supernasro Tech & Performance Forum 19 03 Apr 2014 07:38 am
Help with Alternator belt defflepp1 Tech & Performance Forum 7 20 Sep 2013 09:55 pm
Did the mechanic damage the alternator belt? Hoser General PT Cruiser Discussions 6 20 May 2013 08:41 am
tighting the alternator belt!!help! jjmommy20 General PT Cruiser Discussions 1 26 Mar 2011 08:26 pm
Alternator Belt Question edisapimp Tech & Performance Forum 2 22 Jun 2007 01:50 am
