Anyone know if this is an actual TSB?
Is there a particular reference number? Thanks. |
I posted this link, and that was mentioned.
http://www.ptcruiserlinks.com/forum/...?TOPIC_ID=7102
![]() 2003 GT Inferno Red,5-spd,Eibach Springs,Koni Sport Adjustables, Eibach front and rear Sway Bars, Mopar Stage 1,Mopar BOV,Custom 2.5\" Dual Tip Exhaust (Magnaflow),Hurst Short Throw Shifter, Pioneer DEH6500 Headunit, RF Punch 300 and 301 Amps,RF 12\" Sub and MB Quart Reference and Premium Speakers,Ronal RT 17x7.5\'s with Michelin Pilot Sport 225/45ZR17s, Koni Adjustible shocks, Keystone single scoop, GT Airraid Intake, Mopar Ground Effects Homepage: http://www.cardomain.com/id/ptgtredman http://blueman.ptenthusiasts.net/index.html |
I haven't seen the TSB but the service manager at my Chrysler dealer mentioned this to me. He said that the ATF was now being used to replace the Power Steering fluid.
![]() 2002 Inferno Red PT Limited Photos and more at: http://www.randgraphics.org/PT_Cruiser/demos/index.htm Mercedes Wiki |
Thanks.
I made an appointment to have it checked out. Car runs and turns fine, but I hear that sound whenever it's running for a while and I hold the wheel in a turn. Guess I'll have to remove my Stage 1 emblem from my car too. Rob
here how about this
NUMBER: 19-001-04 GROUP: Steering DATE: Mar. 16, 2004 This bulletin is supplied as technical information only and is not an authorization for repair. SUBJECT: Whistling Sound When The Steering Wheel Is Turned OVERVIEW: This bulletin involves installing revised power steering hose assembly. MODELS: 2003 - 2004 (PT) Chrysler PT Cruiser NOTE: This bulletin applies to vehicles equipped with 2.4L Turbo engines (sales codes EDV or EDT). SYMPTOM/CONDITION: A whistling sound that increases in intensity when steering input is made. The higher the torque required to turn the front wheels, the louder the sound. DIAGNOSIS: Let vehicle warm up for a minute then turn the steering wheel; the intensity of the sound will be proportional to the torque required to turn the front wheels. The intensity of this sound will NOT be dependent on engine RPM, only minor frequency changes will occur with RPM changes. If the whistling sound is heard when the steering wheel is turned, perform the Repair Procedure. PARTS REQUIRED: Qty. Part No. Description 1 05272319AJ Assembly, Power Steering Hose REPAIR PROCEDURE: 1. Replace the power steering pressure & return hose assembly with a revised assembly, p/n 05272319AJ using the procedures outlined in the Service Information on TechCONNECT. Use the following specifications for tightening the hose fittings: FITTING LOCATION TORQUE SPECIFICATION Gear End Return Port 26 - 29 Nm (230 - 260 in. lbs.) Gear End Pressure Port 31 - 35 Nm (275 - 310 in. lbs.) Pump End Ports 31 - 35 Nm (275 - 310 in. lbs.)
\'03 pt gt s1 mopar bov auto patriot blue 1925 modle t pulling truck w/864hp 673ft/lb 2002 harley, 1998 zrt 600 cat http://cpatrucks.org/members/endres.html |
and yes it uses aft+4
brngrhd,
You are awesome. Thank you, thank you.
| Power steering issues | matt87951 | Tech & Performance Forum | 18 | 24 Apr 2009 07:10 am |
| Power Steering Fluid | jmack | General PT Cruiser Discussions | 12 | 25 Dec 2008 11:55 am |
| ATF + 4 or 5 for power steering? | quicksilverdon | General PT Cruiser Discussions | 2 | 21 Feb 2005 05:00 pm |
| I think I'm having a power steering problem! | lumofny | Tech & Performance Forum | 5 | 18 Jan 2005 01:12 pm |
| Power steering leak . . . | gonzowing | Tech & Performance Forum | 5 | 15 Apr 2004 10:28 pm |
