error codes, hesitation, and rough idle
  • 1 Post By Kevkish10
Old 04 Oct 2013, 07:33 pm
Default error codes, hesitation, and rough idle
Good evening everyone,
I have tried searching for my problem and found many post but no solution so hopefully someone can help me here. My CEL came on earlier this week throwing codes P1684 (I know that doesn't involve anything) and code P0172 (Bank 1 too rich). I have replaced the spark plugs (ngk v-power gapped at .040) and coil pack (got a free msd from a SRT friend). That didn't change anything. I will post my symptoms below.
Symptoms: rough idle, when pressing the gas I have a delay before the car actually goes (its like I hit a boost button).
Can anyone please help me here? Thank you in advance.
Old 05 Oct 2013, 12:59 am
Default Re: error codes, hesitation, and rough idle
Kev; change the pcv valve and check for vacuum leaks.
Old 05 Oct 2013, 11:31 am
randyincctx's Avatar
Lightbulb Re: error codes, hesitation, and rough idle
Check the vacuum hose going to the EGR valve,and associated EGR valve control assembly......And maybe even the electrical connector for EGR transducer.(any of these may have gotten 'bumped' or disconnected during the plug change.)
Aka:~KILLER~
Old 05 Oct 2013, 06:00 pm
Mine did that at 30,000 miles and barely started once, but did not show codes. I added AMSOIL fuel system cleaner, changed to NGK Iridium plugs and NGK wires, used AMSOIL air intake cleaner, and replaced with AMSOIL air filter. All has been good and city mpg went from 17 to 21. Hopefully all good for the next 100,000 miles.
Old 06 Oct 2013, 05:47 pm
Thanks guys for the suggestions. I looked at the vaccum lines like you all have suggested and didn't find any holes or kinks. I took the egr valve off and cleaned it with carb cleaner. Although the idle did get better, when I press my gas pedal it still has a hesitation before launching off and when I go to stop the rpms still dip before 500 AMD then goes up to 1000 RPM.
From all of the people that I have talked to say that it possibly could be a bad injector. What do ya think?
Old 08 Oct 2013, 06:23 am
Vacuum leak on intake manifold?
Old 09 Oct 2013, 12:25 am
I am going to look at the intake manifold this weekend. Working 2nd sucks because I have no time to look at the car until the weekends. I am going to visually inspect the manifold and injectors. I will post my findings once I get this done.
dougs likes this.
Old 10 Oct 2013, 01:15 am
Kev; when you had the egr off, did you verify that the valve seat closed completely? Since you improved the idle by cleaning it, it sounds like a lean condition. I'd still change the pcv valve.
Old 10 Oct 2013, 08:21 am
fy9-03pt's Avatar
When ever I look for Vacuum leaks I start the car and use WD40 lightly spray around joints and connections . If you have the Slightest Leak the engine will Rev. at higher RPM
Robert
'02 Engine rattle, error codes, runs rough 76911S Tech & Performance Forum 5 19 Sep 2012 12:48 pm
Car is stalling/RPM's Go up and down/running rough and stuttering/NO ERROR CODES? darkpt06 Tech & Performance Forum 3 28 Sep 2011 06:55 pm
Rough Idle, hesitation PTEuclid Tech & Performance Forum 18 15 Dec 2010 09:24 pm
Rough Idle And No Codes scatgo Tech & Performance Forum 6 07 Jul 2009 09:00 pm
Rough idle, hesitation when starting off CREWZIN Tech & Performance Forum 4 30 Mar 2004 12:10 pm
