Stuck Crank Pulley - Bolt is Out
  • 1 Post By epis
Old 27 Oct 2013, 08:14 pm
tdf tdf is offline
Default Stuck Crank Pulley - Bolt is Out
I have a 2001 PT Cruiser engine (2.4 Non-Turbo) on an engine stand and have removed the Crank Pulley Bolt. I tried yanking the pulley off using a 3 point wheel puller but it will not budge. I even tried applying a little heat with a propane torch to the pulley, and NO-GO. There are no threaded holes that would allow the use of a conventional harmonic balancer puller.
Any ideas why it is so stubborn? Anyone else have this issue trying to get a crank pulley off?
I'm trying to get to the head gasket eventually.
Old 27 Oct 2013, 08:58 pm
Default Re: Stuck Crank Pulley - Bolt is Out
Here is the puller I used. Had to take one leg off and insert into the balancer and reattach the leg. No way to pull out of the balacer. It either comes off or puller breakes.
HARMONIC BALANCER & CRANK SPROCKET REMOVEL AND INSTALL TOOL AND TIPS!!!!
Old 27 Oct 2013, 10:21 pm
tdf tdf is offline
Busted_PT,
The puller I tried was the same type, but is slightly smaller in size. It won't budge the pulley. Maybe I can find a larger puller with more grunt and give it another go.
Old 30 Oct 2013, 07:09 pm
Impact wrench is great help. Here is (was) my setup :
Thanks to Busted_PT for great tutorial
Good luck with your project.
Old 30 Oct 2013, 07:30 pm
Busted_PT,
I used a 4". Legs can't come out. 1/2" ratchet with a pipe fro a longer handle. Like epis said impact is good.
like the strap on the clamp. These can be hard to get hold of. What did you use for a push rod in the crank hole?
Old 30 Oct 2013, 08:26 pm
Just a regular bolt, long enough but smaller diameter then original one or, maybe 3/8" extension for ratchet, sorry I don't remember anymore
P.S.
I think it was extension , yes pointy tip of puller shaft did fit nicely in female part of extension rod
Busted_PT likes this.
Old 31 Oct 2013, 01:41 pm
PB blaster and an impact
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Best Way to get crankshaft pulley bolt chitownpt Tech & Performance Forum 8 02 Aug 2012 07:03 pm
Crankshaft pulley bolt & engine rotation direction JenneK Tech & Performance Forum 6 30 Jun 2012 03:17 pm
WTB - 06506379AA - Engine mount bolt (frame though bolt) wheelgarage Classifieds: Want To Buy 5 04 Dec 2011 10:31 pm
OBX UNDERDRIVE CRANK PULLEY 03-06 PT CRUISER 2.4L TURBO ROCKETMAN8060 Tech & Performance Forum 12 16 Jul 2011 12:38 pm
Under drive Crank pulley for TURBO ROCKETMAN8060 Turbo Performance 3 18 Jan 2010 05:16 pm
