Help with cooling system!!
Old 29 Oct 2013, 01:29 am
Default Help with cooling system!!
Hello everyone
I'm having a problem with water gauge going up to the red after i first drive the car for about a mile after first starting up. I have replaced the thermostat, fan , and radiator cap. After going in the red it comes back down and stays down most of the time. i have burped it once and it still does it . I even drained the radiator.Driving me nuts!! Any help would be greatly appreciated !!
Old 29 Oct 2013, 01:56 am
Default Re: Help with cooling system!!
Hmmmmm
Can you be any more vague?
Are you talking about a pt cruiser?
Originally Posted by Osufan64 View Post
Hello everyone
Old 29 Oct 2013, 09:33 am
Handy_Cruiser's Avatar
Might be a bad temp censer.
Try it with the radiator cap off. If it is truly getting hot, it should start pumping out very hot coolant when the temp goes up. But if the coolant just circulates as normal, check the temp with a cooking thermometer. If it's staying under 200 degrees F, you probably just need a new censer.
Note of caution. The hot coolant can and will burn you. And do not open a closed radiator cap while the car is hot unless you are a hill billy like me that grew up doing such dumb things and routinely gets burned anyway.
Old 29 Oct 2013, 01:09 pm
Yeah sorry DUH Its a 2007 PT touring edition
Bleeding air from cooling system bogaz Tech & Performance Forum 16 13 Apr 2016 06:44 pm
03 gt turbo cooling system...help !!! SteveisKoolaid General Turbo Discussions 5 26 Jul 2013 10:00 pm
Cooling system noises BlueWoody Tech & Performance Forum 7 17 May 2012 08:18 pm
cooling system problems BeagleDad Tech & Performance Forum 6 15 May 2010 03:58 am
cooling system ? cllwyrc Tech & Performance Forum 6 25 Apr 2010 10:35 pm
