Heating issues
Old 03 Nov 2013, 05:57 pm
Default Heating issues
I own a 2003 PT Cruiser touring edition. Recently my temperature gauge started running above the halfway mark. I figured it was low on coolant so I bought some and added coolant. The problem was still there. I replaced the thermostat and the radiator cap. The temp gauge goes all the way up to hot and my warning light comes on but the car isn't overheating. I'm not sure what the issue is with it. My car also does not pump out any hot hair through the cabin vents and does not defrost. I am unsure if these 2 issues are related but its getting to be frustrating. We did drain off some coolant overfill when the needle went straight up to hot thinking we might have overfilled it and the coolant was completely cold. The radiator cap was completely hot though. If anyone has any ideas that I can try and see if it alleviates the issues. Also wondered if maybe the gauges needed a wiring replacement.
Old 03 Nov 2013, 06:09 pm
Default Re: Heating issues
Welcome to the forum SamanthaB
Two immediate possibilities.
First the radiator cooling fan may not be cycling on correctly. When the gauge reads hot, park the car, open the hood and check that fan is running.
Second, the cooling system may have air in it and that air needs to be removed. Was the cooling system bleed after replacing the thermostat?
Air could explain the cabin heat/ defrost problem as well.
Old 03 Nov 2013, 06:52 pm
Hi welcome to the forum
What color is your pt?
do you have any pics?
Are you in any local clubs?
Have you done any mods to it yet?
When you get your car fixed you can still hang out here, there are alot of old fogies here, but I try to keep em young.
Good Luck
Old 03 Nov 2013, 08:31 pm
Good Luck
After reading this I would not blame you for running. But don't he is really the only one. So I would suggest you give it a chance.
I think you have a stopped up radiator.
Old 12 Apr 2014, 11:36 pm
I posted this last year and figured I would update. I was still driving the car which seemed the 2nd thermostat failed. My alternator also decided it was time to got. it was red hot and I had to have it towed from work. $450 dollars later and it ran fine up till today. now im having overheating issues.
Old 13 Apr 2014, 12:01 am
my guess would be the thermostat housing. mine was cracked but couldn't see the crack. get a dorman off amazon, pretty inexpensive. it has to come off to change the thermostat anyway, so might as well replace it.
also, as previously mentioned, bleed the air out of the coolant system afterwards. probably why you have overheating problems. as far as having no heat, could be a bad thermostat. had mine done at the dealer when it was sub zero weather and had them replace it under warranty.
thermostats do go bad.
2016 Kia Soul Plus Black
Tags
coolant, cruiser, gauge, heating, radiator
Over heating issues jesse_smiley General PT Cruiser Discussions 10 18 Jul 2013 03:43 pm
Over Heating issues on a 2000 Limited Edition Automatic transmission Draven76 Europe PT Forum 4 07 Apr 2013 10:52 am
Over heating LincolnG General PT Cruiser Discussions 2 01 Apr 2012 11:44 am
over heating Callygirl Tech & Performance Forum 3 15 May 2011 08:16 pm
O gee! !!!!! my PT is over heating!!!!!!!!!!!!!!!! Ctown General PT Cruiser Discussions 8 03 Jun 2006 07:07 pm
