05 Cruiser won't run
Old 10 Nov 2013, 08:31 pm
Question 05 Cruiser won't run
I have a 2005 pt cruiser with 146k on it. When i turn the key it will turn over,but not run until I spray starter fluid in the air filter and then only for a second or two and then quits. Anyone have suggestions?
Old 10 Nov 2013, 08:49 pm
Default Re: 05 Cruiser won't run
Fuel pump or chip key issue.
Old 11 Nov 2013, 10:03 pm
Unhappy Re: 05 Cruiser won't run
I just checked the error codes and got p0118,p0462 and p0499. Does anyone know what these are and will any of these keep the car from running? Dazed and confused.
Old 11 Nov 2013, 10:14 pm
randyincctx's Avatar
Lightbulb Re: 05 Cruiser won't run
When I bought my PT,it had sat up for 14 months,and I had to do the same thing......One additional thing I did that helped was,while starting it push the gas pedal to the floor,and then once it starts,try to 'feather' the gas pedal to keep it running(even if it runs rough!)....If it dies try again....I had to do this about 3 times before mine would even 'start',and even then it would run for a minute & die.....After about the 3rd or 4th time,it stayed running,but was rough for about 10-15mins.....Then it leveled out,and ran just fine......BTW,mine was almost out of gas when I got it,so I did add about 5 gal. of fresh gas w/about a 1/4 cup of Seafoam in it........Don't know if this will help your situation,but it might.<Good Luck & Don't Quit!>
Aka:~KILLER~
Old 11 Nov 2013, 10:27 pm
Post Re: 05 Cruiser won't run
As for those codes:
P0118 Engine Coolant Temperature (ECT) Sensor Circuit High Voltage(That shouldn't keep from starting/running)
P0462 Fuel Level Sensor Circuit Low Voltage(That could possibly keep it from starting/running)
And one of the best posts for info on P0499 is this:
Originally Posted by CREWZIN View Post
Emissions related.
P0499-NVLD CANISTER VENT VALVE SOLENOID CIRCUIT HIGH
NVLD = Natural Vacuum Leak Detector
Might be a false code. TSB on it:
Component Description:
22. ENGINE AND ENGINE COOLING:ENGINE Bulletin Number: 1802603A
Bulletin Date: Sep 2003
Vehicle: 2003 Chrysler PT Cruiser
Summary:
ENGINE NO START (ENGINE WILL START IMMEDIATELY AFTER CYCLING THE IGNITION KEY), MALFUNCTION INDICATOR LAMP ILLUMINATION WITH FALSE DIAGNOSTIC TROUBLE CODES (DTC) P0016, P0116, P0335, P0339, P0340, P0462, P0498, P0499, P0522, P0622, P1604, P ( NHTSA ITEM NUMBER - 10003985 )
Plus other TSB's
Chrysler Diagnostic Trouble Code (DTC) P0499 related TSBs
Aka:~KILLER~
Old 12 Nov 2013, 07:38 am
Thx for the info. how do i fix the low fuel level sensor? if that keeps it from running.
Old 12 Nov 2013, 07:26 pm
Do i have to replace the fuel pump to fix the low fuel level?
Old 12 Nov 2013, 07:42 pm
Just a quick note about your troubles and your DTC's.(diagnostic trouble codes) When you are using codes to diagnosis a problem write down and then clear them out. Then see if they return.
In this thread what you are posting about the problems and then codes may simply be because the engine is not starting and not necessarily a specific area /part issue. So clear the codes before you go on a search to cure what they say when they may not be an issue.
And one more thing if you are using the key dance to acquire them, forget it. Use a good scan tool to get the codes view them and then clear them out.
randyincctx likes this.
Old 13 Nov 2013, 06:36 pm
Checked the codes with the key and hooked car to hand held computer and both read the same codes twice. Must be in the fuel pump i guess.
Old 13 Nov 2013, 08:03 pm
Question Re: 05 Cruiser won't run
Like Nitro says;Clear the codes w/OBD II scanner,or disconnecting the negative battery terminal for approximately 15 mins,then re-connect,and see if they come back.
Aka:~KILLER~
