Airbag light coming on
Old 02 Apr 2004, 01:01 am
Send a message via AIM to SuzCruz
Default Airbag light coming on
Recently my airbag light has been coming on. It comes on and stays on sometimes, other times it will go on and off with the accompanying dings. I am bracing myself each time I get behind the wheel in fear of airbag deployment. I am probably small enough to be decapitated. If anyone could help I would be eternally grateful. Took my car in for warranty work today only to discover warranty expired 2 days ago. Chrysler refuses to do any outside of warranty work because it is a "grey market" vehicle. Thanks.
Old 02 Apr 2004, 04:59 am
Believe the airbag warning light tells you one of the airbag(s) has a fault in it and may not deploy in an accident. The PCM runs a diagnostic check and keeps track of all the systems. Take it into the dealers to have them repair/replace the faulty parts or it may simply be a loose connector. It's not something you can fix yourself, you may inadvertently set off the airbag if you start playing around with the airbag connections (it has to be discharged first). Maybe MX5 can explain it better and in more detail.
Old 02 Apr 2004, 09:41 am
If the light is on, the airbag WILL NOT deploy in a crash.
There are many sensors, wiring, and control modules in the SRS system.
There will be diagnostic codes in the module memory, even if the light is off.
Any competent tech can repair your fault. You don't have to go to a dealership.
Old 02 Apr 2004, 12:09 pm
SuzCruz, welcome to the forum.
2002 Inferno Red PT Limited
Mercedes Wiki
Old 02 Apr 2004, 02:58 pm
The term "grey market" to me means a car that was built to standards for another country, then brought to the US. I believe they are given a period of time to prove compliance with US safety and emissions laws. Is that the case? If not, I don't know what your dealer's problem is, and I'd go elsewhere.
I gather from MX-5's post that the airbag won't go off accidentally, but it also won't go off when it's needed.
Old 02 Apr 2004, 06:29 pm
CJJ CJJ is offline
Send a message via AIM to CJJ
I've had this happen on several of my cars. It's probably the hair spring in the steering column. This is the device that makes the electrical connection between the rotating part of the steering wheel hub and the steering column. When it goes bad you start getting the airbag light since it isn't making the connection and setting off the warning. Usually cost about $200 to replace.
Old 03 Apr 2004, 05:23 am
Just had this same problem fixed on my Marauder. Dealer found a faulty switch under the passenger seat.
2006 PT Cruiser (NEW)
17X7 Motegi Wheels
215/45-17 Hankook Tire
Front lowered 1.5 inches, rear lowered 2.5 inches
Kenwood in dash CD/Sirius/Six Disk Changer
First of a few mods
2004 Mercury Marauder (Supercharged)
http://www.cardomain.com/id/bigslim2
http://www.cardomain.com/memberpage/484421
Old 19 Oct 2007, 08:31 pm
Send a message via Yahoo to PTConnie
Default Re: Airbag light coming on
If anyone finds out about the airbag light, let me know. I've had my cruiser for two months, and all of a sudden, the light comes on, and ding ding..... goes off for 20 seconds, and goes on again. It's weird, but it only happens when someone is in the passenger seat.
PTC
Old 19 Oct 2007, 08:56 pm
How is it that the dealer calls your car a "grey market" vehicle? That term is usually applied to cars that are imported from out of the country and then brought up to US crash and emission standards. Unless your car was imported from out of the country..... I would have a little chat with the dealer about this. Especially if your only 2 days out of warranty! Hmmmmm......
Old 19 Oct 2007, 10:27 pm
Exclamation Re: Airbag light coming on
I would have the dealer look up the email that has been talked about elsewhere on these forums, Warranty Bulletin D-07-29 , This email sounds like Chrysler wants to eliminate any Gray areas and keep the customer happy and hopfully come back and buy another Chrysler product in the future.
John & Terry
"His" - 2002 Inferno Red Touring Edition
"Hers" - 2003 Electric Blue Limited Edition
Del Val PT Cruisers
Airbag light issues jmack General PT Cruiser Discussions 8 09 Oct 2011 07:29 pm
Parking brake light coming on CHROMEDCRUISER Tech & Performance Forum 8 06 Dec 2004 10:11 pm
Airbag problem - light and chime keep coming on cruiserbabe4 Tech & Performance Forum 9 22 Jul 2004 01:00 pm
Ebrake light coming on. Mr.Barton General Turbo Discussions 3 02 Jul 2004 08:30 am
Brake light indicator coming on cheeseball Tech & Performance Forum 1 10 Apr 2003 01:44 pm
