Bent valves??
  • 1 Post By Busted_PT
Old 17 Nov 2013, 07:42 am
Default Bent valves??
Hi everyone. I've been a member of this forum for a while and this is my first post!! I've always found great tech info here and have been able to make my repairs based on that info.
I have a 2006 cruiser. About 4 years ago, I did the timing belt. Job went fine and car has been great. Friday, the belt snapped while accelerating to get on the highway. I had calculated another 10,000 miles until the next belt change.
Anyway, I'm at the stage of reassembly now. Of course since the belt broke this time, I'm having to realign the timing marks. No biggie - plenty of pics and info here!
What I'm feeling though is a smooth rotating exhaust cam. No resistance at all. The intake cam rotates about a quarter of a turn, then I feel tightness and the cam "springs" forward. Is this the way it behaves when valves are bent or is this the way it feels as it goes round and round?
Thanks!!
Old 17 Nov 2013, 09:07 am
Default Re: Bent valves??
Surprising that the second belt snapped at such a low mileage (assuming less than 100,000 since the first belt change) as the aftermarket belts usually last longer than the OEM belt. Sorry I can't answer your direct question but there's plenty of folks here on the forum that can give you good information. It's Sunday morning here so give it a little time for people to see your posting.
Old 17 Nov 2013, 09:22 am
I honestly don't know. Be sure the cam is turning instead of just the pulley. You can install the belt and start it with every thing else off. Or do a compression test. But usually in the rare case you bend some, its one or two. Not on all cylinders or just exhaust. please follow up.
UptownSport likes this.
Old 17 Nov 2013, 10:51 am
I am not an expert in any way, but my understanding is intake valves and exhaust valves cannot hit each other, only intake and exhaust valves can hit each other, so I don't know what it is you are feeling in the intake....
Others who know more than me will weigh in, I'm sure....
Old 17 Nov 2013, 10:52 am
I read his post to say he felt he had another 10,000 miles to go on the second belt, meaning he had 90,000 miles on it....
Old 17 Nov 2013, 11:21 am
Thanks for the answers so far. I'm at 186,000 miles. I did a redneck leak down test and it seems to be holding. I'm at the stage now of refitting the belt. So far, the job has gone smoothly. Just having a hell of a time wrestling that damn belt over the pulleys.
I'm laying the belt out in the sunlight now hoping to make it a bit more pliable. Keeping the crank and two cam pulleys in line while getting the belt around is enough to make me want to check myself into a mental hospital.
I'll do a proper compression test and see where I am. Think I may have dodged the bent valve bullet though!
Old 17 Nov 2013, 02:15 pm
Yes I would say the compression test won't be necessary since you have done the leak down. For valves anyway. Spring clamps help hold the belt on the pulleys. Use a wrench to pull slack towards the tensioner so the belt slips on. Check the alignment several times. I would take a picture of the alignment. Also start it up with the engine hanging loose. No balancer or covers. If it idles fine and markes still look correct. Then button it up.
Old 20 Nov 2013, 09:06 pm
Just a quick update. I ended up taking parts back to O'Reillys and ordering a Gates kit off of amazon. I'm in the process now of putting it together. Just got my water pump and inner timing cover on. Thought I'd share a tip I've used on motorcycles before I had the correct tool for holding sprockets tight enough to remove the bolts.
You'll think I'm nuts, but a rubber door stopper jammed between the cam sprockets will hold them tight enough to remove the bolts and get the proper torque when reinstalling.
Thanks again to all who replied and I hope to post a success story soon!
Old 20 Nov 2013, 09:37 pm
I will be trying that one.
Bent valves after timing belt bobdole369 Tech & Performance Forum 8 28 Mar 2014 11:49 pm
Important Question Regarding bent Valves/Timing Belt Tommy2Shoes Tech & Performance Forum 19 27 Mar 2014 09:33 am
change you timing belt and bent valves mijohns9 Tech & Performance Forum 3 11 May 2013 06:49 pm
Bent valves? 1971GTX Tech & Performance Forum 8 23 Mar 2012 04:34 pm
Bent Wheels robinjoe Wheels, Tires, Suspension 21 28 Mar 2005 01:18 pm
