Brake Pedal Enigma, need help
Old 20 Nov 2013, 01:51 pm
Default Brake Pedal Enigma, need help
I have a 2001 2.4L N/A with 180k miles on it. In the past few months my brakes have gotten progressively more odd. The first 1/2 of the pedal does nothing, the third 1/4 has some pressure and lightly brakes, the last 1/4 locks the brakes out. I do have ABS, the light never comes on nor does it seem to do me any good. Once they completely failed, I beat the pedal to death and they came back online right before i smashed into another car. I've been to three mechanics, all of them say there is no problem, which I do not believe one bit. She also has a odd idle spike to 3k RPM in park and a strange whirling noise coming from the engine sometimes, no clue if this is relevant, but you never know
-Tom
Old 20 Nov 2013, 04:49 pm
randyincctx's Avatar
Lightbulb Re: Brake Pedal Enigma, need help
Have you inspected your brake booster hose to see if there are any cracks,and that it's fitting tightly on both ends?.......Other than that,the only things that come to mind are failing/worn seals in the master cylinder,or maybe air in the lines for some reason.
Aka:~KILLER~
Old 20 Nov 2013, 06:40 pm
Default Re: Brake Pedal Enigma, need help
Agree with Randy. Sounds like the brake booster or master cylinder. Check the lines from the booster as far as you can.
Tags
abs, brakes, failure
RPM won't go down when brake pedal is pushed! IT JUST KEEPS GOING! HELP! dannypnc Tech & Performance Forum 4 22 May 2013 09:02 pm
Hard brake pedal edscrz General PT Cruiser Discussions 8 25 Feb 2013 07:22 pm
brake pedal question Carl48 Tech & Performance Forum 11 22 Mar 2010 07:51 pm
Brake pedal pulsing UncLarryWasRight Wheels, Tires, Suspension 3 06 Jun 2008 06:12 am
replacement gas pedal and brake pedal?? legion Interior Accessories Forum 7 17 Jun 2004 10:06 am
