Loud engine noise and throttle sputter
Old 21 Nov 2013, 09:19 am
Default Loud engine noise and throttle sputter
Hey guys, same 01 2.4L N/A 180k miles I posted about yesterday. Noe she has some odd engine issues. A really loud noise is coming from the the engine. It's a little grinding, mostly whirling and it gets louder when I push on the throttle. The throttle is also skipping. It will autonomously rev way up for a short amount of time, think 2.5-3k rpm, then fall again. This happened 5 or 6 times this morning on my 3 minute drive to class. The only things I have thought it could be is some bad bearing somewhere and a bad TPS, but my engine light is not on. The old girl keeps falling apart on me...
Old 21 Nov 2013, 11:45 am
Default Re: Loud engine noise and throttle sputter
Noise is very subjective and your grinding/whirling could be anything from an internal malfunction to just something rubbing or vibrating. Need someone close by you to objectively look and listen to the engine to figure out what's wrong.
If the revving is while your in neutral or with the clutch in, it's a built in rev limiter that stops you from hurting the engine.
Old 21 Nov 2013, 12:29 pm
stick or auto? can you get it on video?
Old 21 Nov 2013, 12:36 pm
It is auto. I will get a video once im back in the car.
P304 misfire and loud noise Spidey General PT Cruiser Discussions 16 09 Oct 2017 06:48 pm
loud ticking noise in my engine 96realwe Tech & Performance Forum 5 12 Feb 2011 08:41 pm
Wobble. Loud noise! What do i look for? matthewmilbut Wheels, Tires, Suspension 22 10 Feb 2011 01:37 pm
Loud noise repost! Please help matthewmilbut Tech & Performance Forum 0 07 Feb 2011 11:03 pm
Loud Ticking Noise (please help) alnewp Tech & Performance Forum 6 08 Mar 2009 07:41 am
