P/S reservoir
Old 21 Nov 2013, 09:22 pm
Default P/S reservoir
Fixing a friends turbo power steering leak. The seal between the reservoir and pump looks like multiple wrong size O rings. Can I get this seal or do we need a new pump?
Old 24 Nov 2013, 05:10 am
dirty05's Avatar
Default Re: P/S reservoir
It would be easier just to swap it out if its anything like mine..... Junk yard. It's not available at O'Reillys new.
Old 24 Nov 2013, 03:13 pm
Get Chromenut to help you find the part # and order it at the dealer.
Old 25 Nov 2013, 04:59 am
dirty05's Avatar
Why recommend a dealer part when one that's JUST as good... Well EXACTLY the same as a new dealer part.... Except fluid has never been in the new one. But for $10 instead of on the VERY generous side at least $50. It's a non pressurized container. Not suggesting it but you could use a milk jug if you really wanted to. I don't mean any disrespect and I know I'm new here but am I missing something?
Old 28 Nov 2013, 03:12 am
Send a message via MSN to niel
Exclamation Re: P/S reservoir
Hi guys, long time no see, sorry for it.
I'm having the same issue, my reservoir is in good shape, but the part where the reservoir meets the pump is leaking a lot, and I removed the reservoir and is missing the O ring, I think it cracked, does some one knows what size of o ring do I need? its a special one? or its a standard one of those that handle even brake fluid? or can I just put some black silicone there, wait till it dries? what can I do? I know the leak is coming from that specific part of the reservoir... Ive read a lot of posts and noticed that the melting thing I removed from that nipple was my corrode o ring... so now I'm blank, any help would be cool.
Cheerios... Daniel
"I AM THE DIGITAL SIGNAL PROSESSOR"
Old 28 Nov 2013, 09:12 am
Not sure what you are suggesting but a milk jug doesn't fit our car and The real part is very hard to come buy. Not the same as the na pt.
dirty05 likes this.
Old 28 Nov 2013, 02:18 pm
Is there some one out there that has relocated the reservoir? I saw once a guy at the strip with a moroso in his srt4... but I didn't have the problem so I didnt put any attention how it was... but they have way more space under the hood
Old 29 Nov 2013, 12:43 am
dirty05's Avatar
I learned early on in my automotive career.... Anything is possible with enough imagination, cutting tourch, wielder and beer..... So milk jug is plausible just not practical. I'm suggesting hitting the upullit yard and yanking one from a like car. It's easy to see if its busted or not and most have sinks so you can fill it up with water to test for leaks.... Just make sure its dry before install. I'm all about cheap... but right.
Old 29 Nov 2013, 10:27 am
Same problem will be the seal. I was suggesting getting Chromenut ,who is good at using the parts books. To help with that seal. Not sure if it's a standard o ring or not. Go look at my project thread if you want to see on the cheap. The link is in my signature.
Old 29 Nov 2013, 06:58 pm
randyincctx's Avatar
Lightbulb Re: P/S reservoir
If you could take off the O-ring,and you have a NAPA nearby.....You could take it in to them,and I bet they could find a perfect match for it,and it might be less than a dollar(my local NAPA,would tell me: 'Eh,don't worry about it.')
Aka:~KILLER~
Coolant hose from reservoir Bansheelos Tech & Performance Forum 2 03 Nov 2013 03:48 am
Coolant not returning from reservoir tank Harry2011 Tech & Performance Forum 27 14 Apr 2013 07:57 am
Can't find replacement PS reservoir sawdust123 General Turbo Discussions 3 10 Oct 2012 08:17 pm
coolant reservoir question kruzin4now Tech & Performance Forum 2 13 Oct 2010 11:05 pm
coolant reservoir question pineapple Tech & Performance Forum 13 19 Aug 2009 07:02 am
