Auto transmission problems and codes
  • 1 Post By NitroPT
Old 22 Nov 2013, 04:26 am
Default Auto transmission problems and codes
Hi there
My wife's cruiser has started putting itself into limp mode on a regular basis, I have retrieved the fault codes with a scanner and they are as follows.
p0700 - TCM
p0721 - Output sensor
p0732 - incorrect ratio.
What would be triggering these?
I am assuming that they are connected, the car drives fine, then goes into limp mode.
Any pointers would be appreciated
Thanks
Old 22 Nov 2013, 09:40 am
Default Re: Auto transmission problems and codes
You should get a Transmission shop do a TCM scan and clear. But it looks like it may be your TCM needing to be replaced.
http://carcomputerexchange.com/index.php
Busted_PT likes this.
Old 23 Nov 2013, 03:11 am
Angry Re: Auto transmission problems and codes
Ok, cleared codes, faults have come back,
also p1390 wheel speed sensor, these all seem linked.
is it possible to be a bearing failing, on some trucks you get wierd faults from the hubs prior to a failure.
Old 23 Nov 2013, 08:24 am
The one thing that all those have in common is the TCM. That would be my bet.
Old 23 Nov 2013, 11:27 am
Replace the output sensor. Easy and cheap.
Old 27 Nov 2013, 02:47 am
Hi guys, thanks for the input. I have changed the transmission oil as a precaution and it seems to have helped a little reset codes again and it keeps coming up as 0720.
I drove the car for a while and the speedo and rev counter kept cutting in and out, output sensor kept on the shelf at dealer...... picking it up today to try
01 PT Cruiser transmission codes. twowshores Tech & Performance Forum 3 19 Sep 2013 10:39 pm
2003 auto transmission Tyler Classifieds: Want To Buy 0 17 Feb 2011 02:57 am
PT A/S Auto Transmission Shifter bmeador55 General PT Cruiser Discussions 0 09 Aug 2010 05:41 pm
Worried about auto transmission DIYPTGUY Tech & Performance Forum 23 23 Dec 2009 02:18 am
Error Codes? New 2002 PT Auto bnorth Tech & Performance Forum 2 29 Jul 2002 08:42 pm
