solenoid problem
Old 23 Nov 2013, 02:58 pm
Default solenoid problem
ok, had a transmission soleniod leak, i replaced the solenoid with rebuilt unit it would stall when i put it any forward gear. it was suggested to put the old one back on to make sure its was the solenoid was the problem, everything worked fine but leaks. so i returned the rebuilt unit and bought a brand new mopar solenoid. the dowels stick out alot farther than the the the other two units what do i do?
Old 23 Nov 2013, 05:03 pm
UptownSport's Avatar
Default Re: solenoid problem
Yikes!
Sounds like a defective part.
Old 23 Nov 2013, 10:41 pm
parkerjohn's Avatar
Try researching for TSB's on that particular solenoid. Chrysler might have made a change to compensate for an issue they had with the older unit. Or take your old one in with you and show them the part. Try to match it off the serial number on the solenoid and you might find you have the wrong part.
solenoid Sensor DREDAWG10 General Turbo Discussions 2 05 Oct 2011 07:15 pm
What is a wastegate solenoid 1? chryslergirl Tech & Performance Forum 4 12 Nov 2010 05:07 am
Purge solenoid elmeyer Tech & Performance Forum 0 19 Aug 2009 07:14 pm
Starter/Solenoid problem worseforwhere Tech & Performance Forum 5 23 Sep 2008 02:11 pm
Solenoid 2 (Also 1 & 3 If Anyone Knows) FRM3 General Turbo Discussions 4 11 Feb 2004 01:15 am
