05 PT Cruiser, No start, No spark
Old 23 Nov 2013, 03:40 pm
Rya Rya is offline
Default 05 PT Cruiser, No start, No spark
First off this is my parents car. The story goes, earlier in the week the check engine light came on, but they paid no mind to it. Couple days later they give me a call saying that it wont run. So I try to help them out, Read the codes, (I don't have the specific codes) One was for power steering something or other, and one was for cylinder one misfire.
I go ahead and assume its the coil that went bad. Get a new coil, install it. Try to start it, and no start. Checked for spark, and there is none. Read the codes again, p0700 transmission control system malfunction and p0562 system under voltage. We did have to jump start the car because the battery was dead, after changing out the coil. So is it safe to assume those codes are because of that? Should I go ahead and change out the cam and crank sensors like most people do even though there aren't codes for them? This is on an 05 PT convertible with the 2.4 turbo by the way. Any help would be greatly appreciated!
Old 23 Nov 2013, 04:12 pm
sanatanadharma's Avatar
Default Re: 05 PT Cruiser, No start, No spark
Hello Rya,
Glad you found the forum for assistance.
How many miles on the car? That which I first "assume" is that the timing belt has failed.
If the belt was replaced per Chrysler maintenance schedule, then some other issue is there. Simply buying parts is not best plan.
Are we to understand that it car turns over with the starter but never "starts" and runs? No spark. How about fuel pressure?
Good luck! Others??
sanatanadharma when you are no longer posting in stealth mode and make the availability for PMs then welcome , join and participate on this forum as a supporting member. Until then your responses in most threads will be temporarily removed.
Old 23 Nov 2013, 04:42 pm
Pull the cam sensor off and check for cam rotation while turning key. If you have none, you found the problem.
Old 01 Dec 2013, 03:30 pm
Rya Rya is offline
So a bit of an update. I pulled the cam sensor off and had someone crank the car over. The cam spins so the timing belt is not broken.
Yes the car will turn over, but doesn't fire and run.
Taking the battery to get tested tomorrow (its dead) before I check for voltages from the crank and cam sensors.
2001 PT Cruiser won't start. No Spark oscar_the_grouch Tech & Performance Forum 11 09 Sep 2012 10:25 am
2001 PT won't start after spark plug replaced Eddyb General PT Cruiser Discussions 22 07 Apr 2012 01:49 pm
no start no spark replaced just about everything noluck05 Tech & Performance Forum 6 23 Jun 2011 11:55 am
2004 pt crusier turbo no spark/no start. mjw029 General PT Cruiser Discussions 3 28 Apr 2011 11:21 am
code 340 no start with spark rstanch Tech & Performance Forum 12 24 Nov 2010 10:12 am
