2001 PT no power to fan
Old 23 Nov 2013, 10:12 pm
Default 2001 PT no power to fan
I am getting no power to the wire going to the fan. I checked all circuits and no power. Replaced relays and still no power. AC has not worked in one year. When idle for a long time it overheats and fan does not come on. Any ideas?
Old 23 Nov 2013, 11:07 pm
sanatanadharma's Avatar
Default Re: 2001 PT no power to fan
Fuse #5 (40 amp) in under-hood PDC (power distribution center).
sanatanadharma when you are no longer posting in stealth mode and make the availability for PMs then welcome , join and participate on this forum as a supporting member. Until then your responses in most threads will be temporarily removed.
Old 23 Nov 2013, 11:51 pm
Swapped out with a good fuse and fan still doesn't come on.
Old 24 Nov 2013, 02:29 am
One idea down. I am looking at the wiring schematic. Fuse #5 controls the power side of the fan relays.
Second idea: The coil side of both fan relays (and the A/C relay) is controlled by fuse #12 (10 amp) in the dash fuse block. If you have a 5-speed, this might be it.
If you have an automatic, this fuse also controls the transmission control module.
Tags
fan, overheats
2001 Pt Power Steering Fluid? 01limited94 General PT Cruiser Discussions 2 08 Mar 2013 01:22 am
2001 Power Steering Cap. eac92064 General PT Cruiser Discussions 1 19 Jan 2013 02:14 pm
2001 power steering niose redline1 Tech & Performance Forum 5 02 Mar 2011 09:27 pm
2001 PT Cruiser won't start, no power texasrng Tech & Performance Forum 2 26 Jun 2010 10:12 am
