changing netrual safety switch ?
Old 27 Nov 2013, 07:17 pm
Question changing netrual safety switch ?
anybody change a netrual safety switch 2007 non turbo ? anybody thanks in advance
Old 27 Nov 2013, 07:50 pm
Default Re: changing netrual safety switch ?
Same in either one. Sure you need one? I ask because these just don't go bad as a rule. Changed mine because it got knocked off. Put the shifter in low. Remove the shift lever off the shift rod on the trans. Pull the pan. Drop the valve body. Be careful they're some things that can fall out. Just go slow and watch how things come down. You can see what you need to do from there.
Old 27 Nov 2013, 10:40 pm
went to start battery strong wont click or start in p or n so figure next step
Old 27 Nov 2013, 11:08 pm
I dont think thats your problem. Might be the key switch.
Old 27 Nov 2013, 11:30 pm
hate to start throwing parts at the car
Old 28 Nov 2013, 02:49 am
dirty05's Avatar
How about a more in depth explanation of the situation. It's hard enough to find the issue with the car in front of us and just a blurb on a paper.... Let alone just "hey my car won't start" how about light function? Power with the key on? Brake lights working? Stick or auto? Battery terminals tightened? My first suggestion is to triple check all connectors to the batt and starter, move on to your brake lights and make sure they work (brake light switch could go bad.) The more info the better we can help you.
Old 28 Nov 2013, 07:37 am
i can battery strong lights come on key turned forward and noti automatic moved thru all gears radio works brake lights come on horn works wont start battery terminals clean and tight
Old 28 Nov 2013, 10:53 am
dirty05's Avatar
I hate to say it but Hit the fuse box make sure they are all good then move on to the relays. Not too familiar with the pt starter circuit but it can't be over complicated. Try swapping out relays (if the pt has a starter relay?) And this one is silly..... Hit The unlock button on your remote.... Sounds silly but it has been done...
Old 28 Nov 2013, 11:06 am
Whats the millage?
Old 28 Nov 2013, 03:20 pm
It could also be the WCM causing the car not to start. Is the red VTSS dot lit up steady in the dash? This happened once to my '06 and it caused a no start condition, it wouldn't even engage the starter.
neutral safety switch wiring rob342 Tech & Performance Forum 3 21 Oct 2013 12:26 am
Will not start possibly Neutral safety switch byrne_266 General PT Cruiser Discussions 20 07 Sep 2013 02:26 pm
HELP!!! Not Starting Clutch Safety Switch??? jacobg128 General PT Cruiser Discussions 11 11 Jun 2013 02:40 pm
Neutral Safety Switch??? Moto Tech & Performance Forum 3 21 May 2013 09:06 pm
Fuel safety switch brett185 Tech & Performance Forum 3 26 Apr 2011 02:57 pm
