Engine block coolant drain plug
Like Tree2Likes
  • 1 Post By dirty05
  • 1 Post By Slowrider
Old 28 Nov 2013, 02:45 am
Default Engine block coolant drain plug
Where is the coolant drain plug located on the engine block?
2008 PT Cruiser Touring 135,000 miles
Old 28 Nov 2013, 04:23 am
dirty05's Avatar
Default Re: Engine block coolant drain plug
I've been around the engine a few times and never saw one on the block. You can drain the system from the radiator pretty well. There's a screw looking thing over a shaped part of the bottom radiator support, drivers side. Try that its the lowest part of The cooling system and all the coolant should drain out.
CREWZIN likes this.
Old 28 Nov 2013, 09:38 am
I did two drain and fills using the radiator petcock. I was just trying to see if it was possible to get more out. There appears to be a 3/8th drive plug on the bottom right side of the exhaust manifold. I think that's it. It looks like a differential plug. The coolant was changed at 5 years. I'll test the pH level and freezing point just so I can sleep at night.
dirty05 likes this.
Old 28 Nov 2013, 09:53 am
If it's in the exhaust manifold then it's not a coolant plug. No coolant running through that.
Old 28 Nov 2013, 02:11 pm
It's not in the exhaust manifold. It's below it. I'm not going to worry about it until I have the extra money to get a freeze point and pH tester.
Old 28 Nov 2013, 02:22 pm
Someone correct me if I'm wrong but I believe that is a oil passage.
Coolant System Drain Plug Mansel Tech & Performance Forum 6 30 Aug 2015 04:34 pm
Oil Drain Plug! Tech General PT Cruiser Discussions 9 19 Oct 2009 01:19 am
Coolant Drain & Fill Help lmmegt Tech & Performance Forum 3 07 Sep 2009 10:11 pm
coolant leak from the radiator drain geronimo Tech & Performance Forum 1 19 Jul 2009 02:55 pm
Coolant drain Chz Stage Turbo Kits 6 19 Aug 2003 02:58 pm
