Loss of power steering, brakes & rough engine
Old 29 Nov 2013, 11:19 pm
Default Loss of power steering, brakes & rough engine
Power steering quit working, brakes got hard and are not working and engine jerky! All this at once!! Any ideas??? HELP needed! Will tear into it tomorrow to check. Serpentine belt is still there, fluid under car.
2001 PT
Old 30 Nov 2013, 01:55 am
randyincctx's Avatar
Lightbulb Re: Loss of power steering, brakes & rough engine
You may just coincidentally have 2 problems happening at once;
The power steering could just be low on fluid,or possibly leaking somewhere,further inspection will tell you more....Check around the P/S pump,and lines;Don't forget to check around the pressure switch also,any of these can develop a leak.
The issue with your brakes,and the jerky engine,could be a vacuum leak somewhere.....First place I'd check would be the brake booster hose coming off the side of the air box,it provides alot of the main vacuum supply to the engine,a fairly common problem,it's either come loose,cracked/broken,or someone was doing something under the hood,may have taken it loose,and forgot to re-connect it(usually happens when the air box is removed for some reason,like battery removal,air filter change,engine work,etc.)
Aka:~KILLER~
Engine power loss help demon666 Tech & Performance Forum 18 12 Aug 2013 09:08 pm
Check engine light: Amber Light: power loss dbleclk Turbo Performance 2 06 Jul 2011 06:12 am
Sudden loss of Power Steering after PT being jump started? lanies_ptcruiser02 General PT Cruiser Discussions 16 08 Sep 2010 10:20 am
Power steering Loss driveability Tech & Performance Forum 3 24 Feb 2010 09:31 pm
Loss of Engine Power. b0b88 Tech & Performance Forum 1 03 Aug 2008 05:20 pm
