2003 PT Cruiser clutch problem
Old 30 Nov 2013, 07:11 pm
Default 2003 PT Cruiser clutch problem
Parked my PT at home last night. Came out this morning to go to store and clutch will not engage in any gear. Shifter goes in to proper slot but clutch is not engaging. Gear shift cables appear to be moving normally (top bushing shows wear and didn't check bottom). Could use any help to solve.
Old 01 Dec 2013, 05:46 pm
UptownSport's Avatar
Default Re: 2003 PT Cruiser clutch problem
You're right to mention shift bushings.
Doesn't sound right that the clutch failed while sitting, unless the disc came apart or some other major trauma.
Old 01 Dec 2013, 06:44 pm
randyincctx's Avatar
Question Re: 2003 PT Cruiser clutch problem
Have you checked the fluid level in the clutch master cylinder?
Aka:~KILLER~
2003 PT Cruiser GT 2.4L Modular Clutch and Slave Cylinder Installation InfernoGT PT Cruiser Videos 1 06 Jan 2014 07:57 pm
Pt Cruiser Clutch + Engine ProbleM eponce Tech & Performance Forum 6 17 Aug 2012 10:14 pm
2003 Pt Cruiser -TE Clutch problems, I think. randomzombie Tech & Performance Forum 13 17 May 2012 06:28 pm
2003 PT Cruiser A/C problem blondjenn Tech & Performance Forum 11 07 Nov 2010 02:55 pm
2003 PT Cruiser idle problem oscar514 Tech & Performance Forum 2 12 Sep 2009 11:17 pm
