Noise/Vibration When Accelerating
Old 30 Nov 2013, 07:16 pm
Default Noise/Vibration When Accelerating
I have a 2006 base PT with 134K on it. For the last week, we've noticed a whuh-whuh-whuh noise when accelerating and you feel some vibration through the seats. There is no noise or vibration when in idle, so I am guessing it is drive train related as opposed to engine? Back in October we got new back tires, but no alignment because we hadn't gotten the front tires at the same time. Since this noise started, we had the tires rotated, in case the two older, front tires were causing the noise, but it made no difference. Haven't gotten the two other tires yet, so have not gotten a new alignment. Don't know if that would even be related to the noise/vibration, but wanted to mention it.
Anyone had this issue before, and what did it turn out to be? I've seen posts with mention of wheel bearings, cv joints, axles, etc. Would a mechanic be able to do a test drive and say, "Oh, it's such-and-such!", or is it something they have to just start replacing parts until they find the one that makes a difference?
2006 Base PT Cruiser, bought from dealer in 2008 (used)
134,000 miles now!!
Major Repairs:
Air Conditioning: Fan Assembly 2008, Fan Assembly 2010, Fan Assembly 2012
Steering: Power Steering Rack 2012
Front Wheel Bearing 2013
Old 30 Nov 2013, 07:52 pm
Default Re: Noise/Vibration When Accelerating
Easy enough to check for wheel bearings - jack up a side, grab top & bottom of tire and see if you can get any movement when you push/pull.
Wheel bearings typically make more noise when you turn one way than when you turn other way...
Yes, I think a good mehanic could nail your problem.
Old 30 Nov 2013, 09:21 pm
dirty05's Avatar
Yes, I think a good mechanic could nail your problem.
^ what they said.
Old 13 Dec 2013, 10:08 am
Finally had our appt with the mechanic. It's a bad wheel bearing. I don't know how much it costs to fix yet. Any ideas? It's not the dealer, it's a regular mechanic.
I have a bunch of other items to pay for and am wondering how much I'll be outlaying right before Christmas, lol. Besides the wheel bearing, we need a new battery (old one leaking acid from one of the posts), new wires/plugs (currently has stock, and they stink), clean throttle body, new brake shoes (the front are a 3, back a 4, and inspection is coming up)...
134,000 miles now!!
Major Repairs:
Old 14 Dec 2013, 10:07 am
Default Re: Noise/Vibration When Accelerating UPDATE
It cost $535 for everything, including tax. That was for new front brake pads/calipers, new battery, new plugs and wires, cleaning the throttle body, and replacing the front right wheel bearing. The labor was $175 of that, and frankly, I think most of the labor costs came from the stupid spark plug placement!
There was one item on there I don't know what it goes to: Intake Gasket Set. Which of the repairs does that go with? I looked it up and saw it was for the intake manifold, so does that go with the spark plugs?
134,000 miles now!!
Major Repairs:
Old 14 Dec 2013, 10:27 am
Yes, the gasket is related to plugs. On a non-turbo engine, to get the spark plugs out, you have to take off the intake manifold. The gasket should be re-usable, but I guess yours wasn't.
The price you got is very reasonable - hope you didn't get garbage disks and brakes.
Have you had the timing belt replaced or have proof it was replaced?
Old 14 Dec 2013, 10:51 am
2step's Avatar
The total bill wasn't too bad for all that was done. Fortunately the spark plugs don't have to be changed often. The other items do wear out over time so even though some hadn't failed yet, it's not a bad idea to go ahead and replace them. I probably would have done the other wheel bearing, just because.
Old 14 Dec 2013, 11:27 am
Exclamation Re: Noise/Vibration When Accelerating
Be careful!!! I think a whuh-whuh-whuh sound means a train is approaching!!!
Old 14 Dec 2013, 12:27 pm
They shouldn't be garbage parts. The mechanic is a friend of my father's, so he's not going to screw him over. I've never even talked to the guy; my father handles everything, lol. He also knows a lot about cars, so he would know.
We haven't had the timing belt replaced yet. We've been hemming and hawing because we were planning on buying a new car, but with every repair we have to do (had power steering fixed to the tune of almost $1000 not so long ago, this and some other things brings it close to $2K), we stretch it a little farther. I didn't want to invest the $1000+ into the timing belt if we weren't going to keep it, but I think we probably will get it done shortly, and just put off a new car until next year, providing nothing else goes wrong with it...
134,000 miles now!!
Major Repairs:
Old 14 Dec 2013, 02:49 pm
Hemming and hawing? Wth does that mean?
I know of hemming motor news, the knitting process and rolling sheet metal is called hemming?
04 PT, jerking when accelerating solluna975 Tech & Performance Forum 9 08 Feb 2014 11:45 pm
Problems Accelerating and Whirring Noise? LittleKai General PT Cruiser Discussions 4 17 Nov 2013 07:33 pm
Noise on 2007 when accelerating from stop. Gamer92 General PT Cruiser Discussions 15 06 May 2013 12:52 pm
vibration when first accelerating PurpleMoo41 Turbo Wheels/Suspension/Handling 7 05 Aug 2011 06:24 pm
Slight vibration in steering, squeaking noise coming from wheels, thud when braking thinkinboutit General PT Cruiser Discussions 6 10 Oct 2010 11:31 pm
