The "Handy" Window Switch Repair
Like Tree12Likes
Old 01 Dec 2013, 01:47 am
Handy_Cruiser's Avatar
Default The "Handy" Window Switch Repair
I've been to several salvage yards looking for good replacement parts for my little red 2001 PT Limited. But I've yet to find a good power window switch that works reliably and has all the lights in it burning.
So it was time to take matters into my own hands and fix the original switch the "Handy" way.
I went to Walmart and bought a 12 volt green LED light strand kit. This kit comes with two strands of lights and a little power supply. The lights on my dash appear to be green, but some other PT's may look blue. If you decide to try this, make sure the color matches your dash lights. Also, the power supply will be very useful when positioning the lights in the switch even though it will be removed later on in the process. I believe this kit was about $12.
Next, remove the switch from the car. You can just pry the switch out from the top. I used a non-scratching plastic pry-tool made for such things. After pried out, just unplug it. Then removed the switch buttons. They can just be pried out as shown.
To disassemble the switch, pry the cover off. There are two catches on each side.
After I dissembled the switch, I then filed all the contact points so the windows would go up and down reliably. To do this, gently spread the ears that hold each of the little clear rockers in place. When removing the rockers, make sure the spring loaded pins on the bottom don't come out and get lost. Then take a file and make each contact flat and shiny. Do this on both the switch board contacts and each of the floating contacts that sit below each rocker. Usually a bad contact point will be "cupped" and burnt looking. Once flat and shiny, they will usually work great again for a long time.
Now it was time to fix the lights. Each of the two strands of LED lights in the kit needs to be cut to half length. There is already a factory mark on the light strands showing where to cut. A pair of scissors will work fine.
Insert the two LED light strands into the switch board. One goes on each side as shown. I had to use a pair of tweezers to get them to fit between the electronics. I turned each strand at an angle best I could to shine light through the little holes onto clear rockers. This is where the little power supply comes in handy to light up the LED's while I worked.
Here's what the other side looks like. The light strands should come just to the end of the switch board without hanging out.
Next, I cut the LED's wires going to the power supply. Then I folded them over to the back side of the switch board. I soldered the two wires with white stripes to the base of pin #6 (top arrow in photo). And I soldered the two wires without white stripes to the base of pin #4 (bottom arrow in photo). This will power the LED's without having to run additional wires and without cutting into my PT's wiring harness.
If everything is right, the clear rockers should now shine green when pin #6 is given 12 volts and pine #4 is grounded.
Once the cover is back on, everything should be shining green.
And with the buttons in place, the words "Auto" should be lighted and the little dots on the bottom buttons should light up. Even though there is no LED light shining directly behind the little white window switch emblem, there is enough reflection from in the LED's inside the switch to make it light up.
And as you can see, it looks great. And the windows roll up and down nicely too.
Old 01 Dec 2013, 02:01 am
Default Re: The "Handy" Window Switch Repair
Good write up. I also admire the use of correct tools. I will have to sticky this thread for my own use to upgrade/repair lighted switch plate.
Old 01 Dec 2013, 04:24 am
Teska's Avatar
Well done ! On my switch the two bottom switches are not lit, so I assumed they had no LED's behind them
PT Cruiser 05 base 1,6 liter Electric blue.
Natural gas system build in.
Lowered with FK coilovers.
Installed Mopar sub !
Old 01 Dec 2013, 08:23 pm
podo2000's Avatar
Great write up and photos. Thanks
Old 01 Dec 2013, 08:47 pm
randyincctx's Avatar
Thumbs up Re: The "Handy" Window Switch Repair
Bravo,great job & write-up!......Now see if the same can be done to the rear passenger window switches,in the rear of the center console.
Aka:~KILLER~
Old 01 Dec 2013, 09:22 pm
Question Re: The "Handy" Window Switch Repair
Were you cleaning your ears with a Qtip during this, it looks used
Far Left
Seriously though, looks good
Old 02 Dec 2013, 01:05 am
Actually not EVERYONE can do this mod as he (the OP) has done. SOME master window switches don't allow the bottom switches (rear windows) to illuminate cause the "hole" wasn't cut out. Also if you have the bluw switches instead of the clear ones as the OP has then you are VERY limited in what color you can get green is too dark with the blue switches and red doesn't show up at all. so white is what I went with UNTIL I switched over to the clear switches and red leds.
Old 02 Dec 2013, 01:06 am
Randy,
The rear can not be done as the switches themselves were never made to illuminate.
Old 02 Dec 2013, 01:21 am
Originally Posted by pappasmurf View Post
Randy,
Are you sure it can't be done?......Because my rear switches do have 2 little clear lenses in them.....I think if anybody could put 1 LED behind/under each one,you could,then the only other thing would be to find a hot source for power;They may stay on whenever the cars on(i.e....Power going to the switches).
You'd probably only need 2 of these...Do I have you thinking it's possible yet?lol
http://www.ebay.com/itm/DIORAMA-LED-...ht_1106wt_1219Hahaha...I just noticed the seller's name is Randy!(look at bottom of listing)
Aka:~KILLER~
Old 02 Dec 2013, 01:52 am
Ok. HOLD THE FREAK UP! Last time I looked, mine didn't have the clear windows. Gonna go check mine right NOW! BRB
randyincctx likes this.
The "Handy" Air Intake Mod Handy_Cruiser Tech & Performance Forum 38 22 Dec 2013 11:26 am
The "Handy" Tune-Up Handy_Cruiser Tech & Performance Forum 42 08 Dec 2013 07:54 pm
The "Handy" Aluminum Can Mod To Fix Fog Lights. Handy_Cruiser Tech & Performance Forum 8 28 Oct 2013 01:32 pm
