Instrument cluster "no buss" fix
Old 01 Dec 2013, 11:47 am
Default Instrument cluster "no buss" fix
This forum helped me to fix my wifes PT Cruiser so I though I share some tips:
It has been running reliably but suddenly flashed airbag and engine lamps, chimed and showed "no buss" in the Odo-meter. It is the PCI buss between Engines Control Module, ECM and the instrument cluster which has a contact problem. The cable is violet-yellow and runs from the ECM through the connector/loom which enters the car far left and then goes to connector C106 behind and underneath the fuse box on the instruments panels left side. C106 is a grey big connector which is visible from underneath the panel to the left of the diagnostic connector and to the right of an equal big white C105 connector. A new loom then takes the PCI bus to the instruments clusters big black connector where the violet-yellow PCI buss is the last pin, 38.
I started with the instrument cluster connector (wich was OK), then went to the ECM and finally found C106. As C106 is the easiest to get to (tuck under and jog the connector halves to see if the bus returns) I would recommend starting there, could spare you a lot of work .
Old 01 Dec 2013, 11:17 pm
randyincctx's Avatar
Question Re: Instrument cluster "no buss" fix
Year?....Model??.....Photo???
It's not absolutely necessary,but it would be a nice thing to do.
Aka:~KILLER~
"G" fell off my "Touring"... rockandroller The Detail Shop 19 03 Feb 2015 07:05 pm
03-05 "smooth" PT Cruiser Front Bumper cover and lower valance kda66 Classifieds: For Sale/Trade 2 25 Dec 2013 07:15 pm
2002 Pearl Almond Limited Pt "Custom Route 66 " Edition rt66pt Classifieds: For Sale/Trade 59 04 Mar 2013 12:49 am
Turbo "phhsssss" or "whoosh" sound--Normal? Silenceable? Help! Memark General Turbo Discussions 13 24 Nov 2010 10:56 pm
