Help with ignition cylinder?
Old 01 Dec 2013, 09:22 pm
Default Help with ignition cylinder?
Hello,
Just this morning, the key in my 2002 cruiser stopped turning in the lock. I've been browsing the forums with similar questions, but it seems all the solutions given require that you can turn the key into the run position.
I cleaned it with some PB Blaster and used a little dry lubricant on it, so I'm hoping if it's a stuck tumbler that it may be able to pop back into place. If it's not that, and the actuator pin is stuck or broken, is there any way to repair that if I can't turn the key to the run position?
Is there any way to remove the cylinder if I can't turn the key? Or am I going to be stuck with taking it to the dealer and shelling out a few hundred dollars?
Thanks for any help.
Old 01 Dec 2013, 10:40 pm
Default Re: Help with ignition cylinder?
Do a search on "ignition".
Try moving gear selector in & out of park - try neutral.
Try pushing in on key while turning....
Read this one :
New member - 2004 PT Issues brought me here
Old 01 Dec 2013, 11:00 pm
randyincctx's Avatar
Lightbulb Re: Help with ignition cylinder?
If the key won't turn in the cylinder,it cannot be removed for repair.....The metal pin under the cylinder housing,can only be depressed when the key is in the 'RUN' position.
If the key won't turn,you cannot drive,or pull it with a tow-strap(steering wheel is locked);You'll either have to have it towed,with the front wheels off the ground to a dealer,or locksmith.....But,some locksmiths will come to you.
The cylinder will need to be replaced,and have the tumblers keyed to match your original one,so your old keys will work with the new cylinder.
Aka:~KILLER~
Old 02 Dec 2013, 02:24 pm
Yep, had to have a locksmith drill it out. Thanks for the help, everyone.
Old 02 Dec 2013, 07:18 pm
Most,but not all of the time,when a key cylinder is starting to get worn/go bad,there will be subtle signs like key sticking/not going in or out smoothly,or when turned they will stick or feel resistant to being turned......If they are changed at that time,it's a piece of cake;Once they get stuck....Well,you know?
Aka:~KILLER~
Bad Ignition Cylinder Tumblers dardack General PT Cruiser Discussions 3 13 Mar 2013 03:53 pm
Oil in my #1 Cylinder mikeyt89 Tech & Performance Forum 6 11 Sep 2012 03:22 pm
ignition cylinder jammed/broken? Jenn1709 Tech & Performance Forum 1 31 Jan 2011 11:11 pm
Need new ignition cylinder, if I keep old key will car still start? Smifo Tech & Performance Forum 7 28 Dec 2010 11:27 am
Replacing Ignition Lock Cylinder--Done Matt42 Tech & Performance Forum 2 20 May 2010 10:10 pm
