massive oil/coolant issue
Old 07 Dec 2013, 12:25 am
Default massive oil/coolant issue
I was driving home today, my cars heater started blowing cold air, then I noticed the temp gauge getting a little hot so I changed coarse and headed toward the auto parts store thinking I was just low on coolant due to me having a small leak that I have yet to find.
As I was pulling into the parking lot my oil light came on and I had one big "cloud" of white "smoke" come out of my exhaust. I got the car parked and shut off and then checked my coolant level and seen that the overflow was empty. I also had a large puddle of coolant or oil or a combination of the two under that car.
The oil on my dipstick seemed normal, couldn't see any milkyness to it that would hint towards a head gasket issue but it was dark out so it still might have.
I did a quick search on here and seen that the oil sending unit is a common issue on these cars.
Would a bad sending unit on top of my coolant leak be a cause of my problems or do I have a bigger issue going on here? also where would I start to look for the issue.
2001 pt cruiser limited
2000 audi s4 built 2.8l twin tial 770r
2002 audi tt 225 quattro 35r
Old 07 Dec 2013, 12:34 am
UptownSport's Avatar
Default Re: massive oil/coolant issue
I suppose you could replace the pressure sender when you have the head off, would make that EZ.
Old 07 Dec 2013, 12:36 am
Small steps...
Replace you low coolant with water only. Start your engine and see if you are getting moisture out the exhaust. Also if the oil light comes back on or engine light? If so you will need to check for DTCs (engine codes). Do not use the key dance as you will need to read all the codes and not just a random few that may or may not appear using that method. You will also need to note any and then have them cleared.
The next thing to do is to pressure check the coolant system which should also lead to your mystery leak.
Look for any film in the coolant which may be a sign of crankcase oil contamination from a head or head gasket issue. Also see if you eventually get the indication of coolant in the crankiness oil.
You may need to do a compression test and followed by a "wet" compression test and then a leak down test?
Look at the condition of your radiator cap and any leaks around the thermostat housing.
Old 07 Dec 2013, 12:49 am
I did notice oil had leaked onto my passenger side axel and the surrounding area. I replaced the tstat, the housing and the radiator cap about a month or so ago due to leaking coolant from that area.
Old 07 Dec 2013, 12:59 am
The valve cover may be leaking?
You may want to double check you work, not the labor but the condition of the parts. I have not really been satisfied with any thermostat housing OEM or aftermarket they all seem a bit poorly reproduced. The radiator caps do not seem to seal well on any of them.
Old 07 Dec 2013, 01:19 am
I was kind of thinking I had a leak from the valve cover along with maybe some oil coming out of the sender itself?
Old 07 Dec 2013, 08:35 am
Update. Coolant is low but not contaminated. Same with oil. The oil is a litle dark but not too bad. Def can tell there is an oil leak with how messy the bottom of motor is.
Old 07 Dec 2013, 09:41 am
My car did that. Don't take anything apart. It sounds like you pushed your luck and didn't refill the car when you should have. I've done that...Recently..I'll bet you'll be fine. Don't worry too much, just keep a better eye on it until you figure it out.
Old 07 Dec 2013, 09:43 am
I don't think it was just a pushing my luck on it, there is def. a puddle of coolant under the car and a good amount of oil on the motor itself.
Old 07 Dec 2013, 11:58 am
VegasPTGT's Avatar
I too had an oil leak and thought it was my valve cover but thanks to the guys here on the forum it turned out to be the cam sensor leaking. Replaced that and wa la.. no oil leak. I could have just gone for the oil sensor seal, would have been a lot cheaper but now I have a spare cam sensor lol.
Be Madness Not To.
2004 GT HO
Slap Stick Auto
MSD
NKG
VMS Racing 10.1 Red Plug Wires
Installed Heated Leather Seats
Massive oil consumption/HUGE cloud of white smoke on start up Angels_PT General Turbo Discussions 12 26 May 2017 07:01 am
Turbo Replaced - Massive Oil from Exhaust wadejackson2 General Turbo Discussions 12 15 Jul 2013 06:45 pm
Troubleshoot coolant leak: Photo of Coolant on top of engine radiator cap MarcusO Tech & Performance Forum 7 27 Apr 2013 09:16 am
Massive stall/delay/cutout w/ 2003 Turbo...HEEELP! CraigO Turbo Performance 8 10 Apr 2006 03:28 am
