Rigt Pressure?
Like Tree2Likes
Old 07 Dec 2013, 03:39 pm
Default Rigt Pressure?
What should be the pressure rating for our radiator caps? Think mine is 16 PSI
Thanks
Old 07 Dec 2013, 03:41 pm
Default Re: Rigt Pressure?
Thanks
Tell us about your pt. I run 18 on the turbo.
Old 07 Dec 2013, 03:47 pm
Base 02 non turbo that is on its last legs. Hate to say it but Just don't think it will last. Love it and would like to keep it but I have a cracked head or head gasket leak. This is why I am asking about the radiator cap. Had some overheating problems.
Old 07 Dec 2013, 05:37 pm
i have an 18psi from a 2004 turbo model on my 2002 non turbo PT instead of the 16. i had a cheap 16lb from autozone and it didnt seem to work right, so i upgraded
just curious, why do you think you have a headgasket problem?
Old 07 Dec 2013, 05:58 pm
Overheating because my coolant level keeps going to low. No know leaks. Must be going threw the motor. When I take the cap off and look in the filler neck I can see some bubbles come up. And once in a blue moon when I stop the car I can hear pressure bubbling in to the coolant tank.
Old 07 Dec 2013, 07:47 pm
So what do you think? Right call on the head gasket? By the way a stupid question. I heard the radiator fan is high and low speed. Now will it come on while driving at a high speed then driving at a low speed as needed? Or dose the fan spin at a low rpm then at a high rpm as temp gose up?
rob342 likes this.
Old 07 Dec 2013, 08:14 pm
Like any other computer controlled fan, low speed first then onto high as the coolant heats up...all except the fact that it doesn't matter what the temp is if the A/C is turned on. Then the fan should be running the whole time.
To answer your exact question, the fan isn't needed above about 35mph because there's enough air coming into the front so the computer shuts the fan down.
Old 08 Dec 2013, 01:48 pm
They have a cheap tester that checks the coolant for exhaust gasses. I think it's like a litmus paper type of deal, but I don't know. I never needed it
scatgo likes this.
Old 08 Dec 2013, 03:44 pm
Good idea rob. thanks
Old 09 Dec 2013, 05:25 pm
So how much of a nightmare is it to take the head off if needed?
Low oil pressure Stempy Tech & Performance Forum 17 09 Jan 2013 08:27 am
pressure..... superpug666 Turbo Wheels/Suspension/Handling 11 23 Jun 2011 09:56 pm
Where is the A/C low pressure valve? yl003760 General PT Cruiser Discussions 1 29 Dec 2009 07:36 am
Oil Pressure 408v8 Tech & Performance Forum 4 23 Nov 2007 08:56 am
Oil Pressure THier Tech & Performance Forum 2 28 Jun 2004 06:16 pm
