Broken Trans Bolt?
Like Tree6Likes
Old 08 Dec 2013, 11:44 am
Default Broken Trans Bolt?
2003 Non Turbo.
Manual Transmission Pops out of 5th Gear,
Definitely is the transmission.
I just picked up this transmission, supposedly came out of a wrecked 2002 car with 67,000 miles.
The issue I have is it looks like one of the case bolts had the head sheared off.
Anyone have a picture of one to compare? So I can have this one ready to go and any gaskets on hand when I pull the original.
I only want to do this once.
If it does look like a sheared bolt I have a Couple of options, First I will try and cut a slot in the bolt end with a dremel and get the broken bolt out with a flat blade screwdriver, or I need to separate the case and try and get the broke bolt out with visegrips, or I could use the bellhousing from the original transmission.
Thanks for any help or comments.
Peter
Old 08 Dec 2013, 11:53 am
randyincctx's Avatar
Lightbulb Re: Broken Trans Bolt?
Don't start anything just yet......I'm not 100% sure,but I think that may be an 'Alignment Pin',and not a bolt;Give some time for me to look,and other members to respond......I think it may be one of these,or similar. http://www.ebay.com/itm/Lakewood-Sus...-/390713734703
Busted_PT likes this.
Aka:~KILLER~
Old 08 Dec 2013, 12:14 pm
Default Re: Broken Trans Bolt?
Originally Posted by randyincctx View Post
Don't start anything just yet......I'm not 100% sure,but I think that may be an 'Alignment Pin',and not a bolt;Give some time for me to look,and other members to respond......I think it may be one of these,or similar. Lakewood Suspension Bellhousing Dowel Pins 500" Dia Ford Chrysler Mercury Pair | eBay
That would be really, really, really good.
Peter
Old 08 Dec 2013, 12:23 pm
I have 1 to compare
Old 08 Dec 2013, 12:29 pm
Originally Posted by rob342 View Post
I have 1 to compare
Just pop the case open and grab it with a vise grip. My thread about that here: i killed it.
randyincctx likes this.
Old 08 Dec 2013, 12:30 pm
UptownSport's Avatar
It's broke off alright. You could also look at the trans you have.
You need to check differential shimming if you change bellhousing, and shim it.
I think it should come out, though
Old 08 Dec 2013, 12:34 pm
Post Re: Broken Trans Bolt?
Looks like bad news;In both of these diagrams,it does appear to show a bolt head.....But,yours sure broke off clean,and no marring on the bellhousing from being tightened?
Aka:~KILLER~
Old 08 Dec 2013, 12:49 pm
Do like Rob said;Just take the other bolts out,to separate the bellhousing,and you can easily grab the broken one with some vise-grips.......You probably need to do that anyway,and make sure everything inside looks 'Kosher'.
Aka:~KILLER~
Old 08 Dec 2013, 01:14 pm
Here's a link for the trans service manual.
http://oskin.ru/pub/chrysler-dodge/m...8F_NV_T350.pdf
Old 08 Dec 2013, 01:36 pm
Sorry to step on you Rob, must've posted at same time
Mystery bolt on 2003 Manual Trans split Tech & Performance Forum 2 25 Aug 2013 06:32 pm
All 3 engine mounts failed on 2001 PT Cruiser. The broken bolt is where I need help. Chrismindless General PT Cruiser Discussions 18 25 Jul 2013 07:22 pm
WTB - 06506379AA - Engine mount bolt (frame though bolt) wheelgarage Classifieds: Want To Buy 5 04 Dec 2011 10:31 pm
Broken Motor/Trans mount? cruisin03pt Tech & Performance Forum 4 05 Oct 2011 09:34 am
Broken bolt KingKole02 Wheels, Tires, Suspension 10 13 Apr 2010 12:50 am
