RE; Lifting
Old 03 Apr 2004, 11:58 pm
Default RE; Lifting
Where is the best place to lift up the front end, when changing oil......................
Kennybopaloo
Old 04 Apr 2004, 12:11 am
Buy rhino ramps - auto stores carry them. About $20 or so. They're plastic, hold up to 2 tons, and have a ramp angle that lets you drive on without hitting the body. Easier & safer than jacking.
Old 04 Apr 2004, 12:15 am
Thanks Quick Silverdon, I have a nice 3 Ton Jack that I thought I might use on the Turbo.
Your suggestion is not to use the JACK..............
Old 04 Apr 2004, 12:26 am
There's no single point on the front to jack - just 2 points on side.
Oh, Welcome to the Forum![?]
Old 04 Apr 2004, 12:28 am
So would you consider me jacking her up right under the drivers side door .....
Old 04 Apr 2004, 12:38 am
It's actually right below the front door seam - you'll see a little flat spot in the seam weld. The drain & filter are actually a little closer to passenger side, but pretty centered.
Old 04 Apr 2004, 12:41 am
Thanks for your help.
Kennybopaloo
Old 04 Apr 2004, 01:11 am
It's okay - I'm trying to squelch all those rumors that I'm not good for anything!
Old 04 Apr 2004, 03:56 am
2sb 2sb is offline
If your jack goes far enough under, you can place it in the center of the K-member.
USE JACK STANDS BEFORE GOING UNDER!
Old 04 Apr 2004, 09:38 am
kennybopaloo,I agree with Don.the best way to change oil.IMHO
Is with the Rino ramps. One of the best things I've bought
for my PT.Much easier than Jacks and jack stands.IMHO
Welcome to this forum[^]
04 cool vanila Limited Turbo
Wife has a 03 limited
(Steel Blue)
