Oil on spark end of plugs
Old 11 Dec 2013, 02:40 pm
Default Oil on spark end of plugs
Hello all, I have a Base '03 that had been running rough and getting really bad gas mileage. I also had a check engine light come on. I went to the auto parts store and it came up with a code 0300. I was told it was a misfire due to bad plugs and old wires. It appears the original wires were still on it.
I bought Champion DP plugs and new wires. When I got the #1 wire out it was burned like crazy and the spark end (the thread end) was covered in oil. The rest of the plug was oil free as was the tube. I had the same thing in another plug (#3 I think). All the tubes came out dry and there was only oil on two spark plug tips.
I replaced the plugs and wires and it ran great... for about 24 hours. Then it was back to running ratty. I am about to go check and see if the threaded end is covered in oil on the #1 plug again.
I have been searching on here for possible causes and have seen alot about valve and spark plug gaskets being bad. But it also seems that it would be filling the tube with oil. Since my spark plug tubes are dry would this be causing my problem as well or should I look somewhere else?
Thanks in advance.
Old 11 Dec 2013, 04:44 pm
Default Re: Oil on spark end of plugs
Thanks in advance.
Mileage and you did not say if your PT is smoking. Only way to have that issue is bad rings or valve seals. Not a regular problem here.
Old 11 Dec 2013, 06:02 pm
UptownSport's Avatar
For it to cover plug tips with oil, you'd be reporting symptoms of massive engine problems.
If you're not using a quart of oil every 75 miles, I wouldn't worry about anything inside the engine.
Old 11 Dec 2013, 11:24 pm
Not smoking or burning a lot of oil. Mileage is 120,000.
Old 13 Dec 2013, 09:10 am
Any ideas anyone?
Old 13 Dec 2013, 10:01 am
I'm betting it fuel not oil. Try some Berryman's B-12 cemtool in the gas and see if that helps things. Might be a dirty fuel injector.
Spark Plugs PT_Panel Turbo Performance 2 09 Mar 2012 12:28 pm
How do I take the spark plugs out??? roz84 Tech & Performance Forum 6 25 Feb 2012 08:19 pm
spark plugs ote69 Turbo Performance 28 11 Jul 2010 09:59 am
Where are the spark plugs...? whitbyPT Tech & Performance Forum 10 15 Oct 2008 09:34 pm
spark plugs MNShaleCruiser Tech & Performance Forum 5 12 Dec 2001 03:17 am
