Loud Engine Noise - Roar
Old 11 Dec 2013, 11:03 pm
Default Loud Engine Noise - Roar
2008 PT stock edition, 82,500 miles. Recently my wife returned from a long trip to StL and back (Hampton Roads, VA) and this sound just...happened, really. No lead-in or similar sounds, just started. The engine makes a loud roar when accelerating past 40mph and stays when in motion at any speed above this. No engine knocking, nor slipping belt sound; nothing like that...really it sounds as if the engine is still moving in 3rd gear at far too high a speed, than much of anything else but I can verify in the tachometer that 4th gear is being engaged (3rd to 4th shift point is currently approximately 2400 and drops to 1900, as with the previous two shift points). No grinding, rocking, knocking, nothing like that at all...just really loud. It actually sounds something like it generates a pulsating sound in the engine signature about every four seconds or so. This pulsation is matched to a vibration pulse felt through the accelerator pedal upward into one's foot. I've verified all fluid levels (automatic transmission, engine oil, power steering and brake fluids) as my initial thought was low transmission fluid keeping the gears from shifting properly. Any thoughts would be appreciated, tanx =)
Old 12 Dec 2013, 10:14 am
Default Re: Loud Engine Noise - Roar
Sound is different to one person than another. Have you checked over the engine bay to see if anything is out of the ordinary? Check the air filter components really well as it may have come apart and yo may be hearing the rush of air into the throttle body with going all the way through the air filter parts. Stand outside the car with hood open and have someone rev the engine and see if you can determine where the noise is coming from.
Old 12 Dec 2013, 10:15 am
can you record a video of it?
Old 13 Dec 2013, 10:02 am
Is it making that sound in idle? I just had a similar problem and it turned out to be a bad wheel bearing. The sound would increase in 'pitch', I guess you'd call it, as you accelerated, but it didn't happen at all in idle, so figured it to be in the drivetrain...
2006 Base PT Cruiser, bought from dealer in 2008 (used)
134,000 miles now!!
Major Repairs:
Air Conditioning: Fan Assembly 2008, Fan Assembly 2010, Fan Assembly 2012
Steering: Power Steering Rack 2012
Front Wheel Bearing 2013
Loud engine noise and throttle sputter tomcat706 Tech & Performance Forum 3 21 Nov 2013 12:36 pm
loud ticking noise in my engine 96realwe Tech & Performance Forum 5 12 Feb 2011 08:41 pm
Wobble. Loud noise! What do i look for? matthewmilbut Wheels, Tires, Suspension 22 10 Feb 2011 01:37 pm
Loud noise repost! Please help matthewmilbut Tech & Performance Forum 0 07 Feb 2011 11:03 pm
