rough idle but good with vacuumleak
Old 13 Dec 2013, 09:40 am
Default rough idle but good with vacuumleak
05 cruiser with new iac and new purge solenoid. cleaned throttle body to new. has 64,000 miles. new fan replaced 2 weeks ago. idles below 500 but give a vacuum leak and idles up to 900. took to dealer and say it needs new throttle body. banging my head to figure out what the problem is. any suggestions?
Old 13 Dec 2013, 10:11 am
Default Re: rough idle but good with vacuumleak
Not the throttle body Would be idling higher if that. Do you you have a engine light on?
Old 13 Dec 2013, 10:28 am
Did you have the throttle Body off the car to clean it? make sure everything is tightened down and everything's connected right. Did it idle low before you changed and cleaned things? Might be a problem with the TPS also but I know of no way of testing it.
Old 13 Dec 2013, 10:31 am
2step's Avatar
So is the dealer's diagnosis "needs new TB"? How was that determined, from your description or from their inspection and testing?
I'm guessing you have a non-turbo version and not a turbo which has a lot more possible places to leak. Am I guessing right?
When did the problem start and was anything done at that time such as a plug change?
Are the power, performance and fuel mileage fine except for the idle issues?
Are there any trouble codes when you call them up in the dash display or check with a scan tool?
What is the age and condition of the plugs, plug wires and PCV?
How and who determined that there are no vacuum leaks? These are easily missed and can be located anywhere along a hose, intake mani gasket or TB.
A used but service worthy throttlebody can be had for about $50 and is a simple, quick project to R&R. If that's the problem.
Rough Idle-Replacing the IAC Idle Air Controller engineerrock Tech & Performance Forum 9 07 Jun 2014 07:24 pm
'07 PT - Rough Idle, rough acceleration, and shuts off if it idles for too long La_Bruja Tech & Performance Forum 3 09 Aug 2013 07:50 am
rough idle deafy06 Tech & Performance Forum 4 17 Jan 2012 12:00 am
rough idle while careyk Tech & Performance Forum 1 02 Oct 2009 11:12 am
Rough Idle, Rough @60, check engine light NEW Dystroy Tech & Performance Forum 8 12 Jan 2009 09:07 pm
