Transmission filter change + fluid
Old 13 Dec 2013, 10:16 am
kctobyjoe's Avatar
Smile Transmission filter change + fluid
EVERY CAR I ever had; I believed in some major maintenance at 60,000 miles but now it appears automakers are talking 100,000...I think that is TOO LONG to wait
Changing the trans gasket and filter in the spring in my 'new' 2006; 112k miles and it appears previous owners maintained the vehicle well.
The ATF +4 is bandied about...is that synthetic? My pan I believe has the 14 holes; the report from Chrysler says I have the : DGL 4-speed automatic tranny. What is the preferred nomenclature ?
I bought a drain plug which I will install in the pan after cleaning thoroughly etc upon removal rather than buy the Dorman part.
Unlike my 1997 Taurus I assume no mfr makes a reusable gasket; theTAURUS gasket was 1/8 - 1/4 thick plastic center with neoprene or silicone ribs on both sides; NO WARPAGE; just clean thoroughly and replace
4 quarts from drain to refill; w/o taking out the torque converter ?!?!?
FWIW I bought the AC DELCO filter kit
kctobyjoe
Old 13 Dec 2013, 10:21 am
Default Re: Transmission filter change + fluid
I think the auto trans should be flushed every 50,000 miles.
I fond a place with a flushing machine - it gets all the old fluid out - ATF + 4 only. - cost about $200.
Yes, ATF + 4 is synthetic.
Old 13 Dec 2013, 10:37 am
kctobyjoe's Avatar
Giddyup!
Old 13 Dec 2013, 01:14 pm
I believe 50k is right... AFAIK the schedule actually calls for 48k.
Not sure I'd mess with a gasket. ChryCo "Grey" (IIRC) works perfectly, and is what they recommend using.
Old 13 Dec 2013, 01:39 pm
kctobyjoe's Avatar
I like to do stuff at 60,000 no more...belts; hoses; fluids; filters etc
The AC DELCO box that came in...well that gasket was grey but maybe not the one you are describing; its not cork; its not neoprene. FLAT CLEAN surface torqued CORRECTLY shouldn't fail ever...
On that Taurus I mentioned I NEVER had an issue with that amazing reusable gasket; maybe that was the only one around ;-)
Old 13 Dec 2013, 01:51 pm
Won't lie, Ford has awesome gaskets - they don't mess around.
Old 13 Dec 2013, 10:54 pm
kctobyjoe's Avatar
There are a few different brands of ATF + 4 out there; can EASILY get CASTROL; having difficulty getting Valvoline; PENNZOIL is avail thru an eBay vendor.
Opinions on CASTROL etc...
kctobyjoe
Changing transmission fluid and filter? tcnw05 Tech & Performance Forum 13 09 May 2015 10:14 pm
Transmission Fluid and Filter Change Questions Patrick_Dickey Tech & Performance Forum 32 10 Nov 2013 11:46 am
Transmission fluid filter/pan clearance question? ingram87 General PT Cruiser Discussions 7 16 Apr 2012 09:22 am
Do you guys change auto/transmission fluid? ingram87 General Turbo Discussions 12 12 Apr 2012 05:07 pm
Manual Transmission Fluid Change matt87951 Tech & Performance Forum 22 11 Apr 2011 03:42 pm
