02 Sensors
  • 1 Post By kctobyjoe
Old 13 Dec 2013, 10:27 am
kctobyjoe's Avatar
Default 02 Sensors
I am a big believer in preventative maintenance and replacing parts BEFORE they fail if economically feasible
My 'new' 2006 gets >20 MPG on a trip, in fact like 27.x
I read about issues with the 02 sensors losing their minds. (upstream) MINE look stock; and am receiving NO error codes...but at 112,000 miles and 8 years in service is it unreasonable to replace the sensors BEFORE They go? I use BOSCH in every car I ever owned and NEVER had an issue.
OPINIONS???
drumrooster likes this.
Old 13 Dec 2013, 10:31 am
Default Re: 02 Sensors
I changed both of mine at 100,000 miles with no fault codes showing for the same reason...preventative maintenance. I used new BOSCH sensors.
Old 14 Dec 2013, 01:04 pm
rcktpwrd's Avatar
I changed the upstream sensor in mine last year as preventative maintenance. The car ran noticeably better afterwards and it wasn't running badly before hand. I had about 96,000 miles on the car at the time. I say it's defiantly worth changing, plus it's cheap enough. I got mine from RockAuto for about 25-30 bucks I think...
Joel
www.rcktpwrd.com
Old 14 Dec 2013, 02:45 pm
kctobyjoe's Avatar
I buy LOTS of my stuff there; have been for years...so come Spring or when I get my garage unblocked; upstream and downstream BOSCH 02 sensors it is
kctobyjoe
Old 14 Dec 2013, 07:55 pm
rcktpwrd's Avatar
you will also need to rent an oxygen sensor socket, at least for the upper sensor. I never messed with the downstream sensor.
most all auto parts stores rent them out for free...
Joel
www.rcktpwrd.com
Old 15 Dec 2013, 05:57 am
kc; under normal conditions o2 sensors last 150,000 on closed loop systems. So I've read. If your getting 27 mpg highway with an auto trans, then be satisfied with that. If your mileage drops, I'd change both.
Old 15 Dec 2013, 08:19 am
Danny7627's Avatar
Unhappy Re: 02 Sensors
27 MPG is excellent mileage for a PT. I'd never get that here with all the stop and go traffic in NYC...
Old 29 Dec 2013, 12:10 pm
kctobyjoe's Avatar
I got 27.2 according to the Cruiser computer. This was a 5-1/2 hr. + drive from WV to North Eastern PA; virtually ALL turnpike mileage 65-75 all the way
I still bought the 02 sensors.
Next is a partial rear suspension fix;(Polyurethane bushings) the watts link is clanking' Front end FEELS like it may have been rebuilt; solid as a rock but wil inspect too...
Then I will do the water pump; CAM sensor; timing belt; water hoses + REAL clamps; plugs; wires and super coil. Trans gasket; filter +4 synthetic fluid; Mobil 1 (?) synthetic 5w-30 oil change plus filter.
Rear GAS shocks and front struts at $ availability ;-) after taxes come in ;-)
kctobyjoe
Old 29 Dec 2013, 12:25 pm
UptownSport's Avatar
27? Surely can't be anything wrong with the sensor, unless it's bad in a GOOD WAY!!!!!
You can actually view O2 correction with an OBD reader, this would give you an idea if it's reading too far away from calculations.
Old 29 Dec 2013, 12:43 pm
kctobyjoe's Avatar
I have a reader that I have NOT yet tried on my Cruiser; the one I bought was dismissed by my 97 Taurus; we'll try soon enough!
Yes it was 27.2...
f/s ~ DSP w3 bar sensors OurPTGT Classifieds: For Sale/Trade 0 04 Nov 2013 07:54 am
Need some help testing o2 sensors BajaCapt Tech & Performance Forum 2 12 Sep 2013 04:19 am
OEM sensors. Badglas General PT Cruiser Discussions 9 06 Oct 2012 07:26 pm
O2 Sensors? Georgiachick86 Tech & Performance Forum 5 25 Jul 2011 05:54 pm
o2 sensors ptlvr Tech & Performance Forum 2 18 Feb 2009 07:30 pm
