code 204 - Anyone have any experiance with this one?
Old 16 Dec 2013, 01:54 pm
Default code 204 - Anyone have any experiance with this one?
2001 PT just turned 150,000 miles this weekend. Driving my son to school today the car started running as if it dropped a cylinder. Code 204 came up. I understand that it means there is an issue with the Cyl. #4 injector or wiring. Anyone else ever have this problem? What solutions did you come up with?
Thanks
Old 16 Dec 2013, 02:16 pm
Default Re: code 204 - Anyone have any experiance with this one?
Your right about the code: Misfire on Cylinder #2. Could be: Spark plug, spark plug wire, fuel injector, injector wire, Coil (on one cylinder but that's very very rare) and lastly you could have a vacuum leak on the manifold itself or where the upper manifold meets the lower. Very last (and you needs tests to see), there might be something wrong internally so a compression check of all cylinders to see if No#2 is lower than the rest.
P0420 code Converter Code? 2008/110,000 miles Sarasmiles Tech & Performance Forum 8 28 Mar 2014 07:08 pm
Ecc code jondickson Tech & Performance Forum 0 29 May 2013 11:22 am
Help with one code galeana77 Tech & Performance Forum 5 22 Mar 2013 08:27 am
CODE P0339 NOW, NOT "ALL" FIXED CODE YET HarleyTom Tech & Performance Forum 0 14 Nov 2012 03:23 pm
Code 320. 300 brklnnite718 Tech & Performance Forum 6 16 Jul 2009 08:34 am
