Transmission Problems (I think)
  • 1 Post By txh976
Old 18 Dec 2013, 11:05 am
Default Transmission Problems (I think)
I recently bought an '02 Touring Ed. PT Cruiser, I'm an 24 year old female, fist time buyer and don't know much about cars. Recently my car has been having a heck of a time shifting gears when i'm driving. Sometimes it take as long at 10 seconds for my car to shift gears. My car has never stopped going while I was driving (yet) but occasionally when I come to a full stop my car won't go into dive and I have to restart my car once or twice to kick into drive. I have also noticed that when I driving over 25mph my car has no problems shifting into gears. I have 2 mechanics look at it and both have check the transmission fluid and said its the correct color and doesn't smell so they don't think its going bad, but they couldn't tell me exactly bc neither work on transmissions that much. Has any one else experienced this problem? I'm just worried that the fix will be more than my cars worth
Old 18 Dec 2013, 11:16 am
Default Re: Transmission Problems (I think)
You should check for a Transmission specialty shop and have them do a complete diagnostic check of both the TCM (which control shifting operation ) and line pressure check the transmission. Looking at the fluid and checking the level is very basic and not a technical way to check for issues with the type of transmission you have in your PT.
The sooner you get it checked the better. Continued use could cause other problems or increase the current condition that may end up being more costly to repair.
TCM=Transmission Control Module
WELCOME TO THE FORUM
Old 18 Dec 2013, 11:17 am
I see, so you've taken it a couple "mechanics" but not to someone that really works on transmissions, like a transmission shop?
Jerry
Old 18 Dec 2013, 11:21 am
Jerry
Jerry I am thinking it is probably the solenoid pack, mileage age and most likely lack of good routine maintenance?
It is not that expensive to have a transmission shop diagnosis it and change it out if that is the culprit causing the problem.
Old 18 Dec 2013, 12:54 pm
Thanks for answering! I am taking to a shop tonight after work, I just hope they don't bamboozle me with charges. Is this a common issue with PT Cruisers? I love my cruiser, I hope its no more than $1000 to fix it.
Old 18 Dec 2013, 12:56 pm
Ya I don't think the previous owner took good care of the car. One place mentioned that all it might need is a flush & new filter, but who knows
Busted_PT likes this.
Old 18 Dec 2013, 01:50 pm
If there is a varnish build up around the solenoids then sometimes a transmission service with a positive flush and filter change my clean things up. This is about $100-150 at most Transmission shops. A better shop will diagnosis the issue before making a decision to do any procedural.
If it is the TCM or solenoid pack that needs to be replaced they are still within releasable charges.
With a fast internet look up:
TCM rebuilt range 100-190
Solenoid pack new 60-125
There is also a fluid test that can be done to see what materiel may be in the fluid which can also help determine what the issue is. But it does take longer for that to be done as it has to be sent out for analysis.
Good luck with the shop
Old 26 Dec 2013, 08:56 pm
It turned out that the transmission is blown. I'm going to find insured used one tomorrow hopefully $400 and under) and ive found a mechanic (a family friend) to put it in for $30 a hr. To avoid any future mishaps, what are some common maintenance to keep my cruiser on the road?
Tags
transmission pt cruiser
Transmission Problems KoushMan808 General PT Cruiser Discussions 4 05 Sep 2013 07:51 am
Transmission Problems bustedturbo04 General Turbo Discussions 4 15 Jan 2011 05:19 pm
Possible Transmission Problems emhymas Tech & Performance Forum 1 03 Mar 2009 03:07 pm
Transmission problems !!!! 2004PTCruiser Tech & Performance Forum 7 03 May 2008 08:12 pm
Transmission Problems. PT73 Southeast PT Forum 2 14 Jun 2007 05:59 pm
